bought a project car (r32 gtr). finally got it up and going and its not hitting boost - at all
has hi mount t66 and external gate, boost tap, and power fc, stock bov (currently vented to atmosphere :( )
now i blocked up the bov's to see if they were leaking - still no boost
fiddled with the boost tap up and down - still no boost
rev the car, take it for a drive - wont make any boost whatsoever - not even 1psi
anyone have any ideas why it could be doing this.
only thing i can think of is faulty wastegate but when i had it off the car the spring in it had plenty of tension (gate was hard as f**k to push down)
please help :(
https://www.sau.com.au/forums/topic/363602-no-boost-r32-gtr/
The stock bov should be Plummer back but if it isn't it only really effects idle etc it's not going to completely stop it boosting. And to address this issue I blocked it off. There's no funny sounds. I've checked te ic pipes but will go over them again as i may have missed something
No boost at all but still drives with power fc afm etc tells me there shouldnt be any air leaks.
Either turbo's not spooling or the wastegate is completely open which should still make some boost.
Take the wastegate pipe off and see if the exhaust is exiting it.
Is the engine timing and all the basics set correctly?
Has the power fc been tuned before?
Take the dump pipe off and start the engine. See if the turbine is spinning and increases speed with the engine rpm.
Are the wheels still intact with fins?
Have u tried a different boost gauge?
collapsed cat would still make boost, just not do anything with it.
Can you hear the turbo spool up?
Have you confirmed that it definitely isn't making boost and that the issue isn't with the boost gauge? Stupid question i know but i have seen it happen.
Put it on a dyno. you'd be suprised what you can see when you look at the engine under load.
doesnt cat a cat. rest of exhaust is fine. definitely doesnt boost, or even try to boost.
take it for a drive and it just climbs through the revs fine until you change gear. only problem is it doesnt spool 1 bit,
its as though someone is opening the wastegate as soon as it makes boost, but am 99% sure this is not the case (see posts above)
going to check the fueling of it today.
thanks heaps for input - any input is really appreciated at this stage :(
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
