  • Replies 149
Sludge buildup sounds like a worry. I'll check mine next service.
Sorry to hear about your uncle passing.
do an oil flush at the same time.
and if your gonna check it, change the seal while your there..its what was leaking on mine.
Part number
OEM oil cooler O-ring - B1304-43U00
thanks bud
i always do an oil flush. every car, every service. never had a problem with oil sludge.
also sorry to hear about your uncle.
maybe ill replace all the hoses etc on the new engine before i put it in. would make routing pipes much easier with no car chassis around it lol
yeh but would that much sludge affect the tune if its all taken out?
you wouldnt think so!
maybe its affected oil pressure which is driven directly from the motor, thus engine can rev freely. i dunno, im sure scotty will come along and tell us why lol
i did it at scotts house. he says he didnt think so, until i explained how much was actually pulled out.. i actually scared him and i think he's checking his. he said the same thing about oil pressure and stuff. Its the only thing i did yesterday.. unless in between then my fuel pump is on its way out..
stock pump still? no youre running E85 right so you have a walbro?
hmm might be worth taking my spare off too and checking that........
ive got the walbro in. but i heard someones gone through a few of them(i think craig) but its not making any different sounds or whining..
ok, could that be the cause of your first turbo problem?? lack of oil
yeh i know its the problem..for both of them.. the banjo bolt hadnt been drilled out.. so if this gunk got in there. would of killed it instantly..
Im suprised at how good of a condition scotts stock turbo is.. i think its worth pulling that banjo out and opening it as soon as you get the car.
18 to 19 psi doesnt seem to do short term damage, that little turbo ran hard for 3 months without issue.
Im worried about the sludge but the other engine I had here was fine, I would say yours was just never serviced in Japan mate.
Lack of oil changing by previous owner would explain the sludge (Nissan oil is a mineral base).
Sorta makes you wonder how good these detergent additives in Sougi are if they are not cleaning away the sludge.
Glad to hear the car is feeling better (about time you got a break with that thing!).
EDIT: Bah, Scott got in before me.
Edited by iamhe77
nah your spare one did have abit around the adaptor bolt(if thats what you'd call it) but no where near as much as mine..
well thats just it, not only that i did a motul engine oil flush.. it makes me wonder how much was in there previously.. i think ill be doing another flush on the coming service, and pulling it apart again..
more importantly.. whats everyones opinions on the tune going out? i tried calling Cihan but his phones off..
im getting and AFR of 17-18 on full throttle so im babying it around now.. too scared to push it further..and definitely wont be.
but my Idle is A+ compared to before.
:mellow: isnt anything above 15 'lean'? Pretty sure my AFR's are at something like 11 (super rich)
It could definitely need more fuel now its spinning easier. I cant believe you ran nearly 300kw with a blocked oil pump and did no damage...
hahahahah i thought the same thing.. honestly im suprised i even got up there at all on a fairly rich de tune and that oil blockage problem...
anything above 13 is lean. for us on e85, we dont really need to worry about cruise, but its only on full boost full ball.. before i did the oil fix, i was at about 12 -11 AFR at 22psi.. its the only thing thats changed..
i doubt the brake sensor cable has anything to do with it
Dunno anything about the tune, but at least you have taken quite a bit of stress of the oil pump (removed blockage so considerably less pressure builds up on the outlet side of the pump), thus increasing it's life span.
With those AFR's, at least your economy will be much better!
Just a thought, could the ECU have monitored either a lower than ideal oil flow or increased pressure on the oil pump and "pulled back" the tune, then after the clean out perhaps increased the tune to where it should have been in the first place?
(sorta like a mini limp mode)
Yup, but ethanol wont ping like petrol, it just runs hot so its not too bad for a quick squirt but you wouldnt want to run it that lean for very long.
I always forget you guys are on a different fuel >_<
i doubt it, i dont have any pressure or temp sensors in the oil..
will definitely go on the list after finding this but yeh.
unless we're talking about stock ECU. then i dont know. the only thing ive noticed change is mid to top AFR's.. low range is the same(but much better sinse the oil thing) and cruise is about 2-3 AFR's higher than previous.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
