Hi
I attached the scan copy of the form along with my net bank reference number and pm'ed Shell I just want to know how long b4 we hear anything and how long we wait to get the stuff? Any help will be great.
Thank you
Hi
Thank you
Hi Udi,
Normally doesnt take too long, depending on how busy Shell is at the time :) As Eric said above, they are done in batches too!
Its worth the wait :yes:
  • Like 1
  • 5 weeks later...
Sorry, i'm new, i want to ask if i want to scan the form and send it online and pay for the sticker via bank transfer, who do i pm? thanks :)
PM Shell!!! Our Local (ACT) Moderator and SAU Secretary. :thumbsup:
  • 1 month later...
Hi,
Can you PM Nick aka GoldZilla and also Eric aka Pezhead please to see if they've
a) forwarded the cheque to Toongabbie and
b) it's been deposited
If so, Shell can proceed. Haberfield is no longer used because we shifted to Rydalmere - sorry
  • 1 month later...
Hey guys.
I was a paid member of this club, but i let it ( and my cams licence ) lapse when my car was off the road.
Now that im back and wanting to enter events again... i need to renew my SAUNSW club membership... so can i get some info on how do i do that or do i simply PM Shell and ask her to send me payment details? I dont know if it matters if i have let the membership lapse?
Ill try to PM her now anyway, but im reading she may be busy.
Same with CAMS, ill just have to email them once ive paid up for club member again.
cheers
Hey guys.
cheers
just print the form attached in the 1st post.
scan and attach the completed form to a pm to shell, or send via snail mail to the address listed.
pay monies into the account listed.
sit back and wait.
it does take a little while due to the work load our secretary is under, but it WILL be processed.
thanks, see you at an upcoming event :thumbsup:
  • 2 months later...
I was just going through my records and noticed my membership (12/768) expired June 2013.
I never received a renewal notice. Are they sent?
So I'll have to pay the joining fee again?
  • 4 weeks later...
No joining fee required Russell. Thank you for your honesty.
'Tis just called a prenatal mistake :P
PM Shell
Thanks Terry...contacted Shell and all paid now!!!
Wrong email address in my record.
  • 1 month later...
PM'ed Shell with my membership and payment details.. cheers!
Sweet!
Please give her some extra time to reply and sort everything out - she's VERY pregnant and about to pop out a child any day now, so may be pre-occupied with that for at least a few weeks...
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
