Hey Guys,
If you guys are like me you change your oil every 5-10K's and I know its not a big deal when it comes to draining your oil but I saw this valve which will make it just a little bit easier. Its not expensive shipping is cheap but since I'm going to order one anyway why not save you guys a few dollars, even more if we have a large interest, but otherwise if you like it you can just can go a head and order it otherwise if your intrested in a group buy show some interest and I'll organize something if we get enough people.
JR
Ebay Link
  • Replies 47
We only just ordered a bunch of these for the race cars. Handy little suckers...you'd think they would have been out decades ago? Don't doubt people have made their own custom valves over the years.
Wanna be careful with very low cars though...bashing the sump on a speed bump will probably be a bit easier and the consequences much worse...
That's awesome!
How many mm is the skyline thread?
According to this http://cgi.ebay.com.my/MAGNETIC-DRAIN-OIL-PAN-PLUG-SKYLINE-R32-R33-R34-GTR-/160501240692 12mm with a pitch of 1.25mm I will double check before I place an order too but the ebay link says F-103(12mm-1.25) fits
Nissan: 1990 & on all models(Sentra, Pulsar, Maxima, Stanza, Wagon, 200SX, 300ZX,Gas trucks, etc.)
Birdds you smart nutter you, yea I wanted to get the one with the nipple....giggidy....but they advised against it for low cars
quickvalveuk_634348360753400000-0.jpg <<< Thats the one...I thought I could be even more lazy by attaching a tube to it getting rid of the need for drain pans...buutt probably should just use the normal one
I'd probably grab one depending on price...
They are pretty cheap as is, I provided an ebay link if you want to get it yourself but this is just for us to save a few $$$
They are 100% M12x1.25.
I did the group buy for the Dimple drain plugs.
Thanks, I did lots of checking and research but it's always nice to have a confirmed perspective
I have one of these but im gonna remove it cause im really paranoid that something will hit it and then bye bye rb25.
Battery could you take some pictures and upload them to give us a better idea on how much it is actually protruding. Also do you have the one with the nipple or without?
yeah I would be too..
All you would have to do is run over a tree branch or something could knock it open..
Nice idea though.
Yeh ill try and get a pic on the weekend. Mine is very similar to the one in the first post except the lever has to be pushed in and then turned so it has a semi locking feature...
It is nice not getting your hands covered in oil and then spending 10 mins fishing the plug out of the oil pan lol.
I have also had the magnetic tipped plug which was great until it snapped at the bolt head!
If this is going to be a GB - please use the GB section and follow the GB requirements - we have em for a reason :)
That's awesome!
Until some asshat lets the oil outta your car in a carpark/driveway and then you are in the shit :merli:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
