  • 3 weeks later...
We would love to see it race but it's just not going to happen. Also it's 100% still original from it's last record breaking lap. Still well worth seeing. Here is why it can't race.
Cheers
Marty
Edited by Martin HKS
yeah it's a bit sad it's not running. I mean good work on bringing it out, but if would have been great to go the extra step and compete. I mean static display is ok but you can see that in a magazine. having seen this car in the flesh before at tokyo autosalon and then in real life at tsukuba racing I would say you really need to see it moving to appreciate it fully. seeing it just parked up is not really getting me excited.
still having said that, well done for doing something, but I say overcome those hurdles and race it. who cares when they 'retired' it? fact is it's still a fast car by today's standards.
I guess the idea is that with the GRP A cars it's more a Historic/nostalgia event.
WTAC is a super competitive speed event, that car was only ever built to win or compete at the very top of the field (Other wise it would not be worth the money they spent building and developing it).
I can totally see the reason behind not running it considering it has not been developed since 2007.
I heard recently its record at Buttonwillow has been broken (some 2+ years later Lol) and considering it has not been developed since it would not be ideal to run the car, as much as I and everyone else would like to see it.
Still going to be awesome to see in the flesh though :)
  • 1 month later...
Martin, if you wish to advertise you will need to become a paying trader like everyone else.
See here for further details:
http://www.skylinesaustralia.com/forums/topic/294953-are-you-a-business-want-to-advertise-on-sau-click-here/
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
