  • Replies 132
Posted Images
Not sure I'll make it down to this one.
Got a launch party thursday. Work Party Friday. Bucks Night Saturday. I think sunday I will be sleeping if I'm lucky enough to still actually be alive at the end of it all.
If I manage to rise and can legally drive I might pop down in the afternoon for a while :)
Texikhana is an SAU:NSW institution. We do several of these a year but just don't have our dates for 2012 locked yet.
And it is VERY VERY Fun! If you can come out, do. You can sign on for passenger rides and everyone is very friendly. Most don't mind you hopping in for a ride.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
