Washing your car
23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I hate washing my own car. Two particular so I end up spending 3 hours getting every inch glistening... usually causing more damage then good in the process. Right now it looks like a rally car so have been meaning to get it washed... may take this up.
Try to wash my car every weekend, but if it is raining, I leave it till next week and hope it ain't raining.
Same.
I wash my car properly (takes over 2 hours) each weekend. If it gets dusty during the week then I'll wash it a further 1 - 2 times at the carwash. Gets dust off but no chance of getting grime off.. Those things may aswell spray compressed air instead of soap/water.
2 hours? What on earth are you guys doing? :O
I can have my whole car washed (exterior) in around 15mins, 20mins if im being slow. 10mins to dry, 15-20 if im talking or on the phone.
Interior isn't much more than a wiper over of the dash, doors etc.
A good body detail, with good wax etc = cut times down MASSIVELY. I can almost wash my car just off a high pressure hose because of it, and im talking full brown dirt thats been there for 3-4 days :)
I wash mine once every few weeks.... depends on the weather. I just take it to one of those do it yourself carlovers places...And I use the brush!! hahaha. It's not a show car I don't car about small imperfections. On my previous car I waxed and polished it by hand wax every now and then to keep the black shiny.. Wax helps alot with the finish.
Takes me a while to set up. Gotta unpack high pressure washer, hoses and I'm constantly running inside to fill up more buckets of water etc.
Pre-soak - One bucket worth of suds to go over the whole car and loosen up the dirt
Pre-rinse - Rinse off a majority of dirt, so it doesn't scratch the paint when I wash it
Wash - Go over the whole car with microfiber. 2 buckets: 1 soap, 1 water, rinsing any dirt off the towel to prevent scratching/swirl marks
Wheel wash - Use the leftover soap on a different cloth to clean wheels, exhaust and inside guards (if they're visibly dirty from outside)
Rinse - High pressure rinse
Dry - Chamois or microfiber dry the whole car (except wheels) and have a bucket of water ready to rinse towel if I go over any dirty bits I missed while washing
I then use a disposable cloth (got 1000s due to mum's work) to dry/clean the wheels coz they tend to be the dirtiest, getting into all the little grooves. Occasionally then I will use 'Purple' wheel polish on the chrome lip if they're looking dull/oxidized.
Wax - (Although lately I've been lazy and used a pH neutral shampoo/wax (all in one type thing) which negates this step)
After that I'll gloss up the tyres with some tyre shine and that's the exterior done. Including the setup/packup all that can take me over an hour if I take my time. It works for me and results are flawless.
Edited by jezza boii
I do much the same thing as Jeremy, however wax maybe every 4-6 months. The paste wax I use lasts for a long time.
I'm starting to cut down the time I spend spongebathing it though...it's just too much, and a waste of time. Whilst it's nice to have a car flawless on every panel...unless you're standing closer than a metre away, you won't notice the difference between that sort of job and one you've spent half the time washing less thoroughly. That and, give it half an hour, you already have your first dirt mark again. More frequent washes done in half the time is where it's at.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
