This topic has probably been covered a million times but i cant find it.
Just wondering how much a power an rb25 with stock internals can handle all day every day on a safe tune?
My current project is: rb25det (standard motor)
550cc injectors
hks gt2530 turbo
14 psi boost
apexi power fc
z32 afm
hks pod filter
hks fmic
hks 3.5 inch turbo back exhaust
If there is already a write up can someone please let me know.
Cheers
  • Replies 110
awesome. Id be happy with 250-270 and i drive pretty hard, so i reckon i'll be sweet. As long as i get it tuned properly like you said
Your going to be very unhappy then.
As has been said 230kw is doable from one pushing it as hard as it can go. Friend had a HKS 2535 Kai on his and the most that ever saw was high 230s/low 240s.
Far out Mr Ash, hell I try and be specific about "@ hubs" but still occasionally let "@ wheels" slip, its easy to do given the difference in many cases is negligable and its basically more to quantify that it wasn't on an engine dyno. If you want to get pedantic you may as well make a forum rule that every time someone says a dyno result they say:
Ambient Temp:
Ambient Pressure:
Tyre Pressure:
Tyre Size:
Tyre Profile:
Tyre Temperature:
Tyre Type:
Gearbox type:
Dyno Type:
Dyno Correction method:
Air Intake Temperature location:
Ramp rate:
Tie down method:
But thats just taking silly and running with it :)
It's not occasional in this instance (otherwise i totally agree with ya). Back-to-back testing was done by another user that shows that particular hub dyno reads a solid 40-60kw different. That's a bit more than 2 degree change in ambient temperature :thumbsup:
I say all this because of the thread title "How much can a standard RB25 handle".
People get it in their heads that it's ok to run around making "350rwkw+" when people go around making false claims, when realistically thats really taking a gamble and not a good idea at all.
Over the next 12 months i think we might see a few more 300-320rwkw RB25's fail as there are a few users who have been around that mark now for 2-3 years. So perhaps even 300rwkw isn't that safe.
We have to remember that not everyone wants to go through the expense/drama of a dead motor/rebuild
Fwiw my motor lasted 3 years on 285rwkw pulp and 325rwkw e85 before it finally munched a bearing
That motor was a series 1, 1993 built, 250,000km engine and was a track car of some sort in Japan for god knows how long
Thing saw 7000 revs every time it ran, without fail and was dailied and tracked
End of the day whenever you decide to mod the car and start pushing high 200,s plus on stock engine we all do it knowing all well that theres a chance that the engine might die sooner than expected but theres to many variables how you drive , how much you drive it, and of course the tune.
Of course a car tuned at 350kw which is a daily and never sees all that power being put down will last longer then someone at 280kw thats smashing track work constantly. But atm it seems like the median of what people go on stock is 300kw and also consider running on e85 for abit more security.
550cc injectors
hks gt2530 turbo
14 psi boost
apexi power fc
z32 afm
hks pod filter
hks fmic
Cheers
about twice as much as your turbo can deliver.
Ash this may interest you as i know your a racepace (killer workshop) fan boy.
We see quite a few cars from Racepace through nowadays and the results we see from our hub dyno are very close to the dyno dynamics dyno (generally 10 up or down) they are running... so hub versus roller is moot.
In fact only last week had a bayside blue R34 gtr with t518z's from there last week which pulled 280kw on mine and he had a dyno sheet for 290 from racepace exact same boost.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
