Import Monster Sau-Vic Deca - Round 2 2011 Wrap Up Thread
  • Replies 150
Posted Images
OK so my videos from the skid pan are finally up
There are 2 different versions however both are the same videos
the standard def version is here:
http://sau.loudsx.com/decajune11/lowres/'>http://sau.loudsx.com/decajune11/lowres/
these are 7-10 mg each and will play on most anything.
the high def ones are here:
these are in MTS format and are the full HD and are 50-100mg each.
if you don't know how to play mts files.....stick to the SD ones.
if you want to reuse that's fine, just credit myself and SAU where you use them.
Alternatively i will have them all at the June meeting if u want to bring a usb thumb stick to get them.
enjoy!
Great job mate, looks great!
Tim: You're shit.
I love you too Kieran :blush:
Thank you all for the abusive messages on Saturday night, i don't know what i'd do without you all, i felt so loved/unloved.
Things iv'e learnt being Tim Bryan:
1: Never not drink at a DECA
2: Never not go to a DECA
So i guess I'll see you all in November yeah??
ok so re the videos...
what are ppls thoughts going forward?
I saw from the hits that the low res was much much more popular that the HD videos.
So are people wanting the HD ones going forward or just stick to the Lower res ones?
or continue with both?
Oh and a little reminder...don;t reference where the vid came from when u repost...no videos next time....
cheers
M
cheers
M
You don't want credit for your work???...
Downloading video files is a bit '90's isn't it? There is this new thing....forgot what its called. Ah that is right...youtube
yeah but quality on youtube is a bit crappy, plus if you want to play with the files make a compilation etc then you need originals.
plus lots want to upload the video of them to their own channel. so this way they can.
happy to just upload the lot to youtube, but think there will be a lot less happy ppl!
+1 to all you said Martin.
Uploading and then letting people do the editing/work themselves is much easier from your point of view :)
I'll end up putting it on youtube or something, of course crediting the work ;)
cheers
M
I was at work... so i just downloaded the low res first...
    • With stone chips, you really can't just try to fill them. You really have to sand that spot to lower the edges of the chip, so that the filler will end up covering a wider patch than just the chip. Otherwise, you're trying to have a sharp edged paint surface match up to some filler, and they just do not sand the same and you always end up with a noticable transition. A bunch of adjacent chips should be well sanded back, to round off all those edges, and use a lot (in a relative sense) of filler to raise the whole area back.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
