landrovers have improved much over the years but they still have their problems: electrics being the main
service is very dodgy from dealers as they will overcharge and leave certain things out: replacing brake pads but not machining discs, not reseting service indicators etc
buy from a dealer as they will offer a warranty and always purchase an extended where applicable.
range rovers are great cars, excellent to buy second hand as they depreciate and you can buy a few year old sport for almost half price from new.
I am thinking of buying a Range Rover Sport TDV6 as a second car, has anyone had any experience with this car? Its engine block is made of cast iron whereas the V8 versions made of aluminium. Any comment on its reliability, cost of maintenance, etc is appreciated.
Cheers
My old man is looking at getting something similar.
they have to be the most comfortable 4WD on the market, however you should shop around, make sure you bargin hard.
If you want to compare it to something go and test drive the Volkswagen Toureag. V6TDI or V10TDI, for what you get in terms of options they are very very generous. like Reverse camera, SATNAV, heated seats, sunroof, tow bar. 20 inch wheels.
Have you driven a BMW X5? I just bought a new Land Rover Discovery 4
for my wife ( I know thats not a Range Rover but there must be a lot
of crossover gear) The biggest difference I noticed from the X5 ( I
have had a number of BMWs) is the ride is much nicer in the land rover.
If you want a smooth comfortable ride and like the boxy look, then
Range rover is nice car.
Personally I dont like the steering/handling or throttle response compared
to the X5. The Beemers are so much more sporty, handle better and because
they are about 400kgs lighter they just blow the rovers into the weeds!
My 2c
They apparently also have a habit of engine oil tracking down the loom and crapping out the ECU.
lolz not sure about that one but the rear tailgate switch went after only a few years + rubber components in the suspension crack quite often and need to be replaced - this is for a discovery 3 though
Yes.
My brother's owned a Disco 3 for about 3 years now and it's a pig. We all advised him against it (including my bro-in-law who used to sell them brand new but gave up the agency because the warranty repairs were sending them bankrupt). The Disco has been in the shop more times than I can count, and has left my brother stranded a few times.
I wouldn't touch anything with the name rover in it. THey may be better than they were, but they are still big steaming piles of poo.
^^^^this man knows
And it all depends on what you want to do with it.......a suburban cruiser, who cares buy whatever you like, VW, Rover, X5, Jeep, Cayenne blah blah..........a real workhorse real 4wd, buy a Lancruiser, Hilux, Dmax, Colorado, Prado etc etc doesn't matter how the leather seats feel or good your ride comfort is if it stops and doesn't go between Camerons Corner and Alice Springs, you'll end up like Burke and Wills.
  • 3 weeks later...
I went to test drive one "sport" awhile ago , and these are the thing that happened on the test drive.
The ABS failed and intermitently cut in. seat will not move fore or aft, and the after thee test drive
it refuses to lock up. just kept on poping open after u hit lock.
apart from that, it is a sexy looking "true 4x4"
now I'm driving a Q7.
I dont think my legs are capable of pushing one of the highway.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
