Black sika did not stick to the rubber of the door seal on mine. I put it on, came back in the morning, it was laying on the ground with sika still stuck to the front bar...
LOL >_<
I think self tapping screws might be the way to go.
Anyway, post up some pics guys :P
This is the lip attached to my car - stock R34 GT/GTt front bar.
No the best pic - but once it is out on the road gives the car a "tougher" look.
:thumbsup:
Are they factory headlight washers?? looks good, can't wait to see how mine looks with the lip and freshly tinted windows :D
Hey bro, before you do your lip, I'll take a pic or two to give you some tips about the lip that we have.
Because the front bar lip that we have isn't just a simple curve, so I had to make a slit in the universal lip, then stapled it, to form that shape-ish corner, I think when you see some pics, you will get what I mean lol.
sweet Charles, would appreciate it.
Mark, my ride is more JDM than yours because it has a domo charm :whistling:
seriously though what is a parking antenna >.>
Fancy word for a (short) electric antenna.
It pops up when you want to park in tight spaces, so you can see the corners of your car.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
