Black sika did not stick to the rubber of the door seal on mine. I put it on, came back in the morning, it was laying on the ground with sika still stuck to the front bar...
LOL >_<
I think self tapping screws might be the way to go.
Anyway, post up some pics guys :P
This is the lip attached to my car - stock R34 GT/GTt front bar.
No the best pic - but once it is out on the road gives the car a "tougher" look.
:thumbsup:
Are they factory headlight washers?? looks good, can't wait to see how mine looks with the lip and freshly tinted windows :D
Hey bro, before you do your lip, I'll take a pic or two to give you some tips about the lip that we have.
Because the front bar lip that we have isn't just a simple curve, so I had to make a slit in the universal lip, then stapled it, to form that shape-ish corner, I think when you see some pics, you will get what I mean lol.
sweet Charles, would appreciate it.
Mark, my ride is more JDM than yours because it has a domo charm :whistling:
seriously though what is a parking antenna >.>
Fancy word for a (short) electric antenna.
It pops up when you want to park in tight spaces, so you can see the corners of your car.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
