Just had car tuned again today on Dyno with DVS JEZ from SAU - the results are just so amazing on the street compared to old tune - just totally different to drive so smooth and super responsive from 2000 all the way to 7000rpm and can feel the turbo kick a lot more now....just luurrrv it!! Torque was an impressive more-than expected 546NM. I was thinking it would be more like 460ish NM..
Power started from a super low 132rwkw (stock r34 maps) onto a kinda okay 186rwkw (dyno sheet coming soon)..was hoping for AT LEAST 200 plus rwkw with current mods, but I think because I have the stock dump (rest of exhaust is 3", power and boost started dropping later in the rev range at 13.5psi.. We checked the rubber intake hose too, it wasnt sucking shut. It was a Mainline Dyno which supposedly reads a lot lower than Dyno Dynamics dynos, thats what I've been told..
Although the power is a bit disappointing the result on the street is much better than I expected, just crisp beautiful and yes, fast. The air/fuel ratios are almost perfectly straight - 11.7-11.8 afrs - Jez is amazing and takes his time to tune it bit by bit across little rpm bands - I would say big difference to those workshops that just give u a power figure..
Couldnt wind the timing up more than 14degrees because power started dropping at this stage --- is my dump the restriction??? Also my 100cell metal cat isnt welded properly - there is a slightly smaller than 3" extension pipe that sits part way INSIDE the 3" cat opening on both sides and then welded to the flange and cat..I think because it was easier for the exhaust shop to weld it this way - didnt think it was a problem then, but now think other wise??
We found there was NOTHING wrong with my fuel pump and regulator, it was the afr gauge giving incorrect readings on the road ONLY because it was picking up atmospheric air plus the exhaust air, thus leaning out the ratios.. Two different gauges did this. But when we added a short length thin pipe to the end of the exhaust with the afr sensor inside, the afrs went perfect-- no dramas at all.. this might help other tuners and gave us a lot of headaches..please take note!
https://www.sau.com.au/forums/topic/367462-tuned-r34gtt/
Glad your happy Ron. Your car definately feels alot stronger than the 186kw it made, goes to show that you can go from 132kw to 186 kw on the same boost just with a tune, your car was low to start with so that shows there is an issue somewhere to start with. the power drops off from 5000rpm more than i would have liked. but there was a fair bit of tyre loss showing on the dyno.
couldnt see the intake pipe sucking shut but the syptoms are similar to that.
with the AFR on the road testing, thats got me stumped. your car is the only one i have ever had lean out due to what we suspect is air going into the exhaust tip and giving a lean reading.
next time when i fit your 3 inch dump pipe i will weld in a 02 sensor bung for increased accuracy.
enjoy your car and we will push some bigger numbers when you get a bigger turbo :)
https://www.sau.com.au/forums/topic/367462-tuned-r34gtt/#findComment-5861525
+++1 for DVS Jez, he is a really top bloke, not only in tuning but other mechanical work too, hopefully we will see a shift away from those overcharging 'give you power numbers only' workshops that 'tune' your car...
Anyways I am also happy to now know that my pump, fuel reg and leaning out is not the issue now. As for the afrs leaning out, my exhaust has a perforated exhaust tip where the sensor sits - it could be this messing with the airflow and blowing more air into the afr sensor.
But still dont believe my torque figure 546Nm - 'Simon-S14' (Orange S14) here with a RB25 NEO makes identical torque with almost TWICE as much power as me - 358RWKW?? And 'WASN'T ME' (black R34GTT) also with a RB25NEO makes almost the same power as Simon but with 1000Nm +????
Some funny business going on for sure, sure different dynos give different readings, but not by THAT much..?? These guys' results can be seen on PAGE 33 of the Rb25 Turbo Upgrade thread.
BUT it feels good to know I have that much torque..hurraah! haha..
https://www.sau.com.au/forums/topic/367462-tuned-r34gtt/#findComment-5861618
Jez, can you ask the dyno shop guy to email me a chart showing the power and torque vs RPM not engine/wheel speed which is what I got. I would like to see what power and torque I made at what rpm which is far more important..
cheers
https://www.sau.com.au/forums/topic/367462-tuned-r34gtt/#findComment-5861623
Any chance theres a leak in the exhaust somewhere closer to the turbo? I have a small leak right at the dump atm causing air to be sucked in, venturi style. The wideband fluctuates badly at certain revs now and I guess my last tune was out a bit because of it.
https://www.sau.com.au/forums/topic/367462-tuned-r34gtt/#findComment-5861643
it would be more likely if we had issues on the dyno too which we didnt, after the dyno we did a check on the road and the AFRs were way to lean, tried my innovate and the shops innovate with the same lean result. then we put in a longer venturi sensor adaptor that sits further into the tailpipe which showed as tuned results 11.7-11.8 on song.
https://www.sau.com.au/forums/topic/367462-tuned-r34gtt/#findComment-5861751
awesome, good to see it wasn't any fuel related issue :)
at least you now have a spare fuel reg LOL
I prefer to mount my WB O2 on the dump pipe, less chances of sucking in more and more accurate, as post cat the A/F is not 100% accurate.
https://www.sau.com.au/forums/topic/367462-tuned-r34gtt/#findComment-5861767
thats correct Johnny, always prefer to tune from dump pipe too, unfortunately not everyone wants a bung welded into there exhaust.
the fuel reg was different unfortunately, has the outlet pipe bent at 90 degree's, was the one you gave Ron from a neo motor?
https://www.sau.com.au/forums/topic/367462-tuned-r34gtt/#findComment-5861777
Does anyone know why this is:
'But still dont believe my torque figure 546Nm - 'Simon-S14' (Orange S14) here with a RB25 NEO makes identical torque with almost TWICE as much power as me - 358RWKW?? And 'WASN'T ME' (black R34GTT) also with a RB25NEO makes almost the same power as Simon but with 1000Nm +????
Some funny business going on for sure, sure different dynos give different readings, but not by THAT much..?? These guys' results can be seen on PAGE 33 of the Rb25 Turbo Upgrade thread. '
https://www.sau.com.au/forums/topic/367462-tuned-r34gtt/#findComment-5861800
Usually because of dodgy dyno operators.
https://www.sau.com.au/forums/topic/367462-tuned-r34gtt/#findComment-5862104
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
