  • 1 month later...
hey mate how do you actuate the screamer?
Poke it in the dump pipe?
Same as a normal wastegate; pressure signal from pressurized inlet tract overcomes spring pressure holding wastegate closed.
Open wastegate releases excess exhaust gas (in this case straight to atmosphere, rather than into the exhaust) reducing the volume of gas available to spin exhaust turbine; thus reducing inlet tract pressure and closing wastegate.
The "screamer" name is due to the fact that the unmuffled wastegate is extremely loud; basically like an open exhaust, while the wastegate is open.
I used a turbosmart 45mm wastegate plumbed in before the turbo, it just dumps excess exhaust gasses to stop the turbo shaft speed from increasing once 26psi is achieved.
I have since plumbed the screamer back into the exhaust which made the boost skyrocket to over 40psi, i dropped the controller down but the tune has changed completely, back to the Dyno again...
There must be a hell of a lot of excess gas from the wastegate!
Is it worth (or can you even fit) a larger dump/ front pipe set up to reduce the back pressure? Does integration angle of the Wastegate pipe into the exhaust cause the boost spiking?
Have you seen BOBBYr34's wastegate venturi set up? That wouldn't take long to fabricate... :blink:
post-49633-0-88438200-1313757661_thumb.jpg post-49633-0-58284800-1310467413_thumb.jpg post-49633-0-41323800-1310467527_thumb.jpg
Not telling you how to row your own boat by any means mate; just curious.
Cheers, Dale
They merge at the 4 inch cat body, not the best flowing setup but more than adequate IMO. The reason for the boost spike is the increased pressure in the exhaust compared to just venting it. Once the controller was setup again the boost level was fine but the tune is still out, especially as the turbo spools.
I will try and get a pic today when I remove the front pipe again.
HOLY FUARK how did i miss this thread!
the epitome of AWESOME!!!
i was just talking to my uncle the other day about getting a gigantic turbo for my stag. so it can just be a lag monster.
i can cruise around as if it was N/A all day and then open it up when i want to! lol
LOVE IT!
I never said 500hp is ordinary, it simply isn't a lag monster with a modern turbo and decent setup. Personally I would prefer a slightly smaller turbo for street use on a heavy wagon.
Bolt an old T88 on a 25 or 26 then you will see what laaaaaaaag city is like.
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
