True, no-one can tell me when any part will go bang, there is definitely plenty of load on the gearbox now but its not like I can drop the clutch at 7k, the power comes on smooth and the torque converter dampens the torque output. Perhaps it has some more in it? I would be happy with a safer 350kw by going to the GTX3076 and not maxing it.
jeez someones getting a little sensetive lol.
he doesnt know this, and yes i havnt read of one pooping after reaching its limits either, but i have also not seen or read about a VQ25DET running over 350kw at the wheels. have you?
and im pretty sure no tuner wants to 'pop' a customers car
No, not at all.... I just find it funny hearing that it will go pop running that kind of power when the only basis for comparison is either the RB25det or the VQ35de.
I know of none running 350kw at the wheels... but how many have tried? I've read about the 2.8L VQ25det in Japan running 315awkw but that is running a VQ35de crank and TEPS rods/pistons. I'd love to see and reckon it would be golden at around 350-360 with the 3076 as a reliable daily but it ain't my car nor money and I am only going on what I "feel" the engine could do. All speculation of course :)
Exaggerate much Aaron?
I just found out the VRS top end Nissan gasket kits are discontinued so I hope I can find a suitable gasket kit to do the job. The full gasket kits for a VQ25det through Nissan are nearly $600.
Ok, just for you Alex... :)
Aaron turned up today after he heard the new turbo arrived, he helped me rip his 3071 out and fit the new GTX3076.
I decided to fit the smaller 0.82 rear housing instead of the 1.06 Tial. I was pleasantly surprised at the improvement in response, it seems like it would actually boost off the line now with a little stall. The tune is set for Wednesday night so I will let you know how it pans out.
Sounds good. Great move on the housing. Will change it significantly I think. Video of dyno please!
Make sure get a really good accurate Indication of the speed, we didn't go past 6k because it just peeled over, but that was well off the speedo in 4th. I suspect it's good for 210-220 at your rev limit. Both my tachometer and speedo read significantly high.
Ok, will do.
Gladly the 18's put the informeter speed spot on, only the speedo in the dash is out 10k's at 100. I will try and get footage of that too during the run. What do you want displayed? Speed data will still only go to 180 but that will do as the dyno will be in wheel speed axis anyway.
On second thoughts, does the dyno just store your data from last time? If so, just use what you did your previous run on. You want to see the difference in response, and don't want to stuff it up by messing to much with the speed.
I'd love to see the 71v76 overlayed if possible.
Well, no great results yet, as soon as we strapped the car down to the dyno we realised the slight overheating issue I have been having for a while was actually a blown head gasket. We did a carbon test on the cooling system and got a positive result for exhaust contamination. It looks like either a head rebuild or another engine is going in. It's very similar symptoms to what Gleeson's car is having, perhaps its a common issue/fault? I may look into the pathfinder cooling mod after all Cam. :)
With the boost at around 19psi it was flowing over 330kw still so there is good power there, at least 350 comfortably, perhaps more. Now to find an engine. :(
Alex, the 76 graph looked almost identical to the 71 graph, just at lower boost. Transient response is much better though, looks like a good turbo match for the engine.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
