Too bad you couldn't go for a quick spin last night mate, would have been interesting to compare it now with how it was a month ago.
As an aside, just for shits and giggles, next time you get on a dyno try dropping the correction by another 20%. I'm sure that will be useful for you to compare the progress any changes have made...
Edited by iamhe77
Out of interest, what is the top power figure for a GT3071 on an RB25, on E85?
You ran out of flow at 341kw, on an auto gearbox, right?
Not sure, I think its good for over 360 on a good setup but how often do you see the coin spent? Stock cams, manifolds and internal gates just don't cut it.
good stuff scott im glad to hear it all went well you should seriously get down to calder/heathcote and see if you can improve on your time
I will come and keep you company one cold Calder night. When is the next one?
I will need another sucker to sit in the stands, take video and freeze to death. Any takers?
If I could get to mine easily I would do it on my car but there is no room on my setup.
I lol'd. Rb people don't know about tight spaces and packaging :P
Mainly what I wanted to know is does the v6 have any advance over the rbs? Saw a rb25 with e85 and 26 psi go for 330kw at unigroup in the 3071 thread. I think that was a pretty good set up from what people were saying. Comparable result?
You can lol but then you haven't seen a HKS low mount cast manifold with a GT30 based turbo on it which requires a shave of the engine mount (due to the lack of room) but to add insult to injury I have an ex-S1 Stagea RB25 in the R33 and the oil drain sits higher than the original block which means that there is almost no way to reconnect the drain.
I wouldn't never complain about space constraints otherwise, certainly compared to the tight packaging on VQ powered stageas.
The turbo was maxed out in Mick's case and seemingly on Scotty's at similar power levels so dyno-wise I think the results were comparable. To me it indicated that the compressors were maxed out. Mick's setup on E85 is a peach.
My GT3076 was stronger everywhere compared to Mick's GTX3071 on 98 ron both tuned at Unigroup which is why I still think the extra coin required for a GTX turbo doesn't get you ahead of what was already available. I am pretty sure my GT3040 would perform line ball with a GTX3076. The 82mm comp was limited on 98ron but with E85 it would make a low budget +350rwkw.
Mmm, sounds fun. Lots of cut knuckles all round.
Scotty, I guess we will see the difference in your mph when you get it down the track again.
My 3037 is stronger nowhere.... Lol, actually, might be winning from 2500 to 3000 cause I have boost! But thats about it!
ive entered for saturday scott
You can pre-book Calder?
Im keen to see the mph too, and if I can pre spool this setup.
I noticed there was a 3037 result of 360kw in RB land the other day but that was with the t3 rear, not sure what your housing is yet, perhaps it would make around the same being external gate also?
Isn't Micks still internal gate on stock manifold though..stick it on a 6boob with ex gate and she could pump quite a bit more..350 maybe..
I'm rather surpised Scotts made the power it did with the auto and all..I dont know if its the larger rear housing and gate or just a dyno variance but the figure hes got now is what i would of expected from the 3071...and the figure he had before is what it should have now...
What difference does the manifold make when the compressor is maxed? I would expect it to come on earlier and hold boost better but peak power won't change.
We could sit here and wonder whether the stock manifold maxed out but then we saw a similar number on Scotty's car with a larger turbine housing.
Im not certain the compressor is maxed and that a decent manifold could quite easily allow for a little extra up top..How many 3076s make 360kw with a stock manifold on RBs, I cant think of any off hand, but there are plenty on top mounts...
So you think a larger turbine on Micks would have much effect...?
A larger turbine would make it more docile everywhere and I don't think he would make any more power on E85. On 98ron for sure he would make more up top but suffer down low. When it stops making power and isn't pinging it is probably out of flow but this is just and opinion and we will need more results to know definitively.
I don't know many RB25's with GT3076 and 360rwkw but most would change the manifold when thinking about going over 300rwkw as a matter of course....then again most cars I know are run on 98ron still due to a lack of availability of E85 around here.
It will be interesting to ask a few tuners what the max of the stock manifold is with E85.
'The compressor is maxed' equates to 'The compressor cant flow any more air in the current configuration without creating excessive heat causing loss of power.'
I think with an uncompromised setup using 3 inch short cooler pipes, the best flowing cooler around with water spray, 5 inch side pipe, screamer, ported with cams, manifold etc the 3071 may hit 400 perhaps. In the real world we are compromised obviously, noise and height restrictions, lag worries, restrictive intakes, each step back you lose power but it's a road car at the end of the day.
I like that every person craves a different setup, each build I am part of requires custom design and r+d and trialling new ideas will always be beneficial even if there are no gains.
Speaking of new ideas, this is the VQ block cooler I designed. It is similar to the 'Pathfinder" cooling bypass mod but modified to suit an easy install and fitment to any VQ block. I have been testing it out with surprising results, hopefully the logging data will show a similar lowering of temps. The main benefit of this being easy cooing system bleeding which was the main thing I was after, the thread will attach to a ball valve, to which a funnel could be added for easy filling and air purge. These cars are a pita to bleed stock and I wonder if my head gasket wouldn't have failed if this was in place oem.
I haven't worked out a final cost for it yet, I will start a thread on it soon if anyone is interested. :)
Nice work mate; got to be happy when your engineering nets a good result.
I would like to see this get off the ground; it would be worthwhile for no other reason than simplifying the cooling system bleed procedure. If it improves cooling system efficiency; even better.
Edited by Daleo
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
