Hi all,
Getting my car back on the road soon and it will have new plates. So i thought i might take the opportunity to pick my own.
Not after a custom one, just something subtle that a select few might understand and something most people wouldnt look twice at.
Here is what i have come up with:
SAU-33T
SPL-30L
JDM-30L
NAG-47A
RB-30-GT
RB-3033
Any suggestions? Or just keep what the RTA give me.
https://www.sau.com.au/forums/topic/369685-help-me-pick-a-plate/
