There's more than meets the eye than just getting a hole filled.
Still got all my teeth after 62 yrs but I don't know how long that'll last.
Had to get a rogue tooth out when I was 10.
Had root canal therapy 2x with caps x2.
Still have 8 wisdom teeth that haven't come out and I'm into my 7th decade, so the longer they stay quiet the better.
Never had any bad infections and I wouldn't want any.
I've heard the infections can get into the mandible and kill you.
Had all my mercury fillings out (as I was brought up on unfluoridated water + sugary sweets > caries)
All been replaced.
On the lighter side...
http://www.youtube.c...h?v=zcigt7UTxhM
How's your dental health?
https://www.sau.com.au/forums/topic/369824-dental-health/
  • Replies 55
mine could be better. i have a few holes in my teeth that i need to get fixed, but lack of health cover is holding me back. really can't afford to pay the dentists next holiday out of my own pocket (and i can't afford health cover right now either), but then again, health insurance companies pay bugger all of the cost and what it costs me to get it is probably about what it would save me. i also have a wisdom tooth that has come out at a slight angle that is pushing on the others, as well as it sits lower than the others. i've put up with these for a few years now and they don't bother me, but i keep an eye on them.
my boss had a wisdom tooth taken out that had a big hole in it. then developed a dry socket. then the pain killers he was on destroyed his stomach lining.
https://www.sau.com.au/forums/topic/369824-dental-health/#findComment-5894662
Earlier this year, had 2 wisdom teeth removed in the chair; one partially erupted (under the gum) and the other fully exposed.
Mr "Partially Erupted" had a pocket of filthy black infection below it when removed, and needed 7 stitches to close the gum. Sockets took several months to close fully; did salt water gargling and reduced alcohol to reduce the likelihood of a dry socket.
The longer you leave troublesome widom teeth, the worse they are to remove; aparrently as time goes by the roots become hooklike, and do more severe damage when finally removed.
These hooked roots can entangle nerves along the jawline and make their removal complex & expensive; something to consider if you have "mobile" wisdom teeth.
Other than that; one root canal and NO fillings! Looking at having veneers done on my 4 upper incisors as I have damage under the enamel that it a bit unsightly.
https://www.sau.com.au/forums/topic/369824-dental-health/#findComment-5910802
ouch,
I have about 5 fillings I think.
How many people seriously floss their teeth though?
https://www.sau.com.au/forums/topic/369824-dental-health/#findComment-5915378
  • 3 weeks later...
I've just had 4 wisdoms removed, one root canal and 6 fillings... Why? Because I left it 5.5 yrs after I was told my wisdoms needed to come out and they caused that much pressure in my mouth that they moved all my teeth, 7 of my teeth cracked and needed to be repaired, they took my top 2 out in the chair 2 weeks ago and they roots were hooked, my bottom 2 came out Tuesday in day surgery and they had to drill back into my jaw as my mouth isn't big enough and that's how far back my teeth were. They also had to cut through part of my cheek. My root canal gets the final cap next week and I now have to wear a plate because of the damage to my jaw from the pressure on my teeth. And to think, I've always looked after them perfectly and its because of how expensive wisdom tooth removal is that I didn't get them done earlier :(
https://www.sau.com.au/forums/topic/369824-dental-health/#findComment-5949127
I had 6 wisdom teeth removed, I am extra wise.
No in reality I am a mutant as only 1 in 200000 thousand people have them and it hurt like shit because in removing the extra 2 they cut a hole from my mouth into my sinus and had to cover the hole with skin from the inside of my cheek! That said my surgeon was pretty awesome I was eating real food after 3 days, had no bruising and didnt even miss a game of rugby!
https://www.sau.com.au/forums/topic/369824-dental-health/#findComment-5949182
Wow I feel sorry for you, drilling back into the jaw? I've never heard of that, sounds painful :/
I used to have poor teeth when I was a kid, had to have steel caps on about 4 teeth. I'm 22 now and I think I have about 6 fillings and 1 wisdom tooth is coming through. Only recently I've made sure I go to the dentist to get my checkup every 6 months.
https://www.sau.com.au/forums/topic/369824-dental-health/#findComment-5949184
  • 1 month later...
I'm banking on Stemcells to grow back my teeth..
had an abscess come thru just on take off from hawaii once.. worst 8 or so hours of my life.. followed by three days of dental visits caus the f**kers couldnt get it right the first time.. i had apparently taken too many pain killers i pointed to the sore tooth and apparently it was ok.. yeah root canal so its all ok huh...
i hate dentists..
https://www.sau.com.au/forums/topic/369824-dental-health/#findComment-6012478
i hate dentists..
Did they recommend a crown after RCT?
That's because there's less stress on the tooth > less chance of future fracturing. Costs 4 figures tho'
Then shoot the dentist :P
https://www.sau.com.au/forums/topic/369824-dental-health/#findComment-6012495
I've had the root canal for over 2 years now without a crown, couldnt afford it either. its holding up fine :)
i think they did all 4 roots in the tooth too. so there isnt really much tooth left. will get crowns when i got the cash..
or stem cell haha if it ever happens which no doubt will be within the next 10 years or so.. good bye to the high end dental industry when that happens
https://www.sau.com.au/forums/topic/369824-dental-health/#findComment-6012945
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
