@ PaulR33, Rolls, GTSBoy - If MAP wasn't as good for performance then why is it incorporated with the the PFC D-Jetro (higher end) ECU package?
I think the main reason that the D-Jetro version was made to handle MAP is that there was a period of time when everyone thought that the only way you could do a big power RB26 was to delete the 6 throttles, put in a big single TB and run MAP sensing. That got them away from the various problems that they were having with AFM pulsations etc etc, got them away from perceived (but not necessarily real) problems with multiple throttles causing restriction and otherwise interfering with "tuning". It is certainly true that if you're having AFM problems (either from not being able to get big enough ones, or from turbo inlet pulsation/backflow/whatever, then going MAP will certainly make your life easier. But it is not essential if you know why you are having problems and know how to design around them or design them away.
FWIW, an RB20 runing a Microtech with MAP and IAT is easier to get to reduced cruise fuel consumption and make a bit more power than running Nistune (as an example). A Nistuned factory ECU will retain a lot of other niceties that the Microtech misses out on, so the Microtech experience is not all as good, but in terms of making power and getting the mixtures right, it's perfectly workable. The same is true of a big power RB26, naturally enough.
Tuning resolution has very little to do with the accuracy of a tune. Dont ever let tuning resolution sway your judgement on what ecu to use.
The BA-FG V8 engine is speed density based and only uses 2 1x14 lookup tables to map the entire engine operation. And it still gets through euro3/4 emmissions compliance.
Bingo, most factory ecu's dont use "base maps" anymore, it all based on ve calculations and lookups.
Yeah just checked Google and NS. I can confirm I had fail searches! Thanks for the clear up.
PFC Pro only has launch control.
But I have some points I'd like to clear up too, perhaps STATUS can shed some light on this too:
@ PaulR33 - Your stating that MAP won't produce better results as oppossed with a MAF.
@ PaulR33, Rolls, GTSBoy - If a MAP sensor is based on a table with direct input then wouldn't you be able to tune it finer without having inaccuracies unlike the MAF? If MAP wasn't as good for performance then why is it incorporated with the the PFC D-Jetro (higher end) ECU package?
Sorry if it's starting to sway off-topic, but I believe the nitty gritty bits of information is important before laying cash out for either a PFC or NIStune.
Remember that the D-Jetro Doesnt HAVE to run a Map sensor. You can still run AFM('s) but have the option of running a MAP sensor. So above all else the D-Jetro Gives you the option to run a MAP Sensor based system if you either think its better or dont want/cant afford to buy two Z32 AFMs etc for higher horsepower
Or thats what I think anyway, I'm no expert lol :P
Well in that application it is modelled as 2D linear algorithm lookup table but it does become 3D once cam phasing is used.
And as for MAP based systems - they are getting very complicated these days and manufactures are now using artificial neural networks to model cylinder fill. And at then end of all that most systems(Bosch) still use a MAF sensor to determine cylinder fill and only fall back to the ANN when the MAF fails.
In my mind there is nothing that beats a MAF in terms of metering of air into and engine. The more complicated engine's get (variable cams, variable length manifolds, direct injection etc etc) the better off you are going to be in using a MAF sensor.
Hi!
Since you know both system, has the PowerFC a higher resolution?
By that I mean on Nistune you have a certain number of 'load-cells (TP on the X-Axis))' is this any different on PowerFC?
I'm a tuner, I do powerfcs, Vipec, and Link.
Played with a nistune, it is by far the best on a budget, and just as capable as the powerfc, if not more capable.
The others are for higher performance applications.
just wondering if a modified Z32 ecu running nistune will run the auto the same as an r33 ecu would in regards to timing changes on shifts?
Interested to know how you went with this Trent. Get asked this a few times but no feedback from those who did do it. The Z32 ECU with AT image just passes though the sensor information to AT ECU but I remember you had an issue with TPS control to the AT ECU. Did you get that sorted?
From what i have read the 33 controls the AT from the ECU, thats why you cant use a power fc on an AT 33, is this wrong?
Wrong. Depends on model skyline
Earlier ECUs with blue connector plug like ECR33 have an engine only ECU with TX/RX lines going to a separate AT control computer. ECR33 PowerFC probably doesnt have the AT control lines to the AT ECU for ECR33. Not sure I dont work with PowerFCs to confirm this
For Stagea and ER34 the AT controller is build into the engine ECU (grey connector plug with extra wires)
  • 3 months later...
Wouldn't you just get a remap done on the rb20 computer? Would work out cheaper i would say unless you really wanted nistune.
A remap is a pain in the ass to do as you have to do one chip at a time, takes the same amount of time as doing a full nistune real time map and gets much worse results. Nistune you can remap live, have map tracing, it is the same as tuning a full aftermarket ecu.
Difference is night and day in the results.
How long dose it to install and tune a nistune in a r32 rb 20
How long is a piece of string? What is done to your rb20? A nistune is $400, how long and how much the tune is depends on who, what, where etc.
Edited by Rolls
As for installing, it only takes 5mins max to get the ECU out of the car, same ammount to get back in. To do the daughterboard install inside the ECU probably didn't take Matt (Nistune owner) more than 15mins to solder it in, someone competent with micro-soldering shouldn't take more than an hour. As for how long the tune will take, depends on the tuner (just a max power tune, or taking the time to do low/mid cruise etc)
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
