Import Monster Sauvic Deca Motorkhana - 2011 Round 3
achoo
 Share
  • Replies 244
Posted Images
From memory long wang anything under 55sec is pretty good. Best drivers on mini wang get under 25sec.
Good to know, I'll be aiming for about 1m20s then :P
How do you guys normally travel up there?
I'm heading up on Friday Night after work, do you normally convoy up there or just meet at the Motel?
Was planning on leaving from Melbourne CBD at approx 5:30pm or so... (picking up a few guys from the city on the way)
We used to organise convoys but it all just got way too hard to work out.
People leave at various times during Friday.
We all hang out at the motel on Friday arvo / night, so just meet us all there :D
Good luck with that! Ring Rd will be standstill until at least 6.30-7pm
Either leave by 3pm or don't bother until after 7pm. It'll take you an extra 45-60mins if you try and go in peak, if not more. I tried it once, never again.
Ask your boss to let you go early Simon. I'm leaving Doncaster 4.30 - 5.00. Last time I left straight from work at 4.30 it took a really long time to get to the Hume. I'm just glad I didn't leave any later..
Ha, good point :P
Bit tricky with the guys I've gotta collect on the way...
Meh I'll give them some notice and they can suck it up and leave early as well.
:thumbsup: <--- Good friend.
Or just go the back way like I do (if you happen to live close enough) through Yea & Seymour and you avoid all the traffic.
That's axactly what I'll be doing this time as I'll be leaving after work and will be wanting to avoid the traffic!!!
I cant remember the last time I worked on a DECA Friday :(
I'll probably oraganise a convoy up on the Friday night if anyones interested simply because there's like 11 of us in our group going up together.
I owe you drinks this DECA mofo, ps I'm going up Friday night too!
 Share
    • Opened up the cluster to inspect the gauge itself for signs of damage and it looks good. Got curious since that needle doesn't go back to a "neutral" position by itself (it stays in the same position when ignition is off. so I manually moved it to 1/2. Connected it back, turned on the ignition and the needle started moving up! Not sure what's up with that but before that the needle was way down below empty like fully south west. There's always a chance that the needle moved slightly the first time I tried and I didn't notice because of how slowly it moves and how far it was from the markings. I don't know if the current needle position is accurate so I'll fill it up and see where that brings it. I guess I'll try to adjust it manually if it doesn't get to F. Looks like the needle position is relative and not absolute? Thanks all for your help and patience!
    • You're confusing two different responders and more than one issue. The stock Neo ECU boost sensor is used by the ECU for protection purposes. It is essentially only an overboost sensor. It is not used for determining engine load for fuelling or ignition purposes. That task falls solely to the AFM. Any aftermarket ECU that either has an onboard MAP sensor or a plug in one, will use the MAP sensor as the primary load sensor. Or I should perhaps say "can", rather than "will", because some of them have the option of using other primary load sensors. That MAP sensor is not for the same function as the stock Neo boost sensor. The reason I recommended against a plug and play ECU is that they are intended to run a particular engine and usually in the car that the particular engine came in. So, if you have a transplanted engine in a different car, with some parts of the original missing (such as the boost sensor, for example) and therefore likely non-standardness of the loom and its insertion into the car's loom, then it is very likely that you will run into the same problems with needing to fix up wiring to make it work that you would with the stock ECU. And, if doing so for the stock ECU is enough of an obstacle that you start considering a standalone plugin as a solution, it should become clear that the plugin is quite possibly not the solution you'd hope it to be. It would just lead to more of the same type of problem solving work to get it going. In the above paragraph and in my earlier post, the lack of the boost sensor is not critical. It was just used as an example of something that we knew you did not have right, such that the stock ECU would not work. I took that as an indicator of a reasonable probability that there were other related problems hiding there.
    • I can think of two places in my city of <1.5million population that specialise in automotive instrument repairs.Unless you're out in the wilds of Quebec, you have 3 major Canadian and 3 major US cities within the same distance as the single nearest city to mine. Surely there is somewhere you could send it.
    • I never cared for twins but whenever these conversations came up, I always presumed the higher number represented a larger turbo. Learn something new everyday.
    • Interesting, I've never seen a failure like that before but with the age of these cars and the general questionable-ness of all kinds of parts these days you can't rule anything out I suppose. Boost leak testing the boost control system would've revealed this though.
