I'm from Knox area, guess meet somewhere along the way
went on the BP website and used store locator there's one on Cooper St, Epping
so maybe meet there and take Hume freeway up and turn off at Goulburn Valley Hwy and follow it up to Shepparton
Corner of Cooper St and Hume Freeway
its about a 2hr drive from there...
So say meet up at 5.30-5.45am for 6am depart?
Here's a map of meet spot
Let me know if this is a suitable meet point, haven't been up to deca before but have used this BP before for a Winton meet.
If you were thinking of another servo let me know and well work something out
Anyone else driving up Saturday morning feel free to suggest a meet point or come along to this meet point.
  • Replies 244
Posted Images
Please do not leave later.
Too often people have been arriving 15-20mins before driver briefing starts which doesnt leave enough time to check in, get car prepped/scrutineered etc etc.
If you do this you will miss your first event. There simply isn't enough time to deal with late comers and hold the whole event up as a result.
Should add, I won't be competeing, just pop in for a look - hence my might be come later.
For these who is, arrive there around 8am.
2 Deca's ago you got me lots of drinks cause you got sick of me complaining I was sober lol
I thought it was for all the abusive messages about not turning up for the last deca!
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
