Hey guys I have searched now for hours and hours and cant find anything relative to what my situation is, I have a r34 gtt series 2, and my tcs and slip light were on for a week or so of first owning it, reset the ecu and it went away all was good and now it comes up every now and again, the car doesnt missfire or anything and the engine light doesnt turn on at all, car idles fine, i have just replaced the spark plugs and the idle has gone up from 800 to about 1100 and also when you rev the car it doesnt go straight back down to idle anymore, it floats at about 1800 and then goes to around the 1100rpm mark.
I did the ecu test and have a nissan conzult cable and I came up with error code 17, i think it said abs or throttle sensor or something like that, what could it be? its really pissing me off now.
Also im getting really bad fuel economy, 200kms to a tank, checked the o2 sensor on the conzult program and the voltage is around .80 on idle, could it be the o2 sensor, and what should the air fuel ratio be on idle?
Also the car has a slight pop not a full backfire here and there, the car is running standard boost with a pod filter, blitz bov and 3" exhaust, it used to pop alot more regularly but i have tightened the bov a little since and its not as often. Also where can I buy a caliper rebuild kit? as my calipers are getting noisey and I have been told that its the slide on the caliper? and to rebuild the caliper.
Any help is really appreciated in advance, thanks.
https://www.sau.com.au/forums/topic/371720-a-couple-problems-with-my-r34-gtt/
  • Replies 73
Um, easiest stuff first. You have opposed piston calipers. There are no slides. Without knowing what sort of noise your calipers are making, it's a little hard to know whether to tell you to rebuild them (or get them rebuilt by someone who knows what they're doing) or just to put new pads in and get the disks skimmed.
200 km/tank is ridiculous. O2 sensor could well be stuffed, or your coolant temp sensor could be stuffed. Or your thermostat could be stuck open. 0.8v on the O2 sensor is not correct. It should flick between something close to zero volts and something close to 1v (say 0.2 to 0.9 as a guess) and should do so at least once per second or so. Although, at idle there is often not enough temperature to keep the sensor working properly so it can and will slow down. Nevertheless, it should average to about 0.5v which is about the middle of the sensor's curve. If it is really sitting at 0.8v then it is probably borked.
As to the stuff about your TCS light, TPS sensor, high idle etc....these have all had numerous threads lately. Short version, you could well have a leak letting air into your induction tract (and boost out! and this could well lead to high fuel usage too) and you should check that the TPS is plugged in and then you could look at checking that the TPS is actually working.
First thing to try is put the std BOV back on and see if that fixes all the idle and 'anti-stall' point...
Next thing is the TPS voltage is in the correct range for the ECU - unsure of the exact range but i am sure others will know.
hey well the breaks are making a creaking sound, and you could kind of feel the creak in the pedal if you know what i mean, i was thinking maybe it needs a bleed? pads are as new, also the calipers move a little when the break is pressed? i called nissan for a rebuild kit and he said it comes with the boots and rubbers for the slide aswel? I got the car with this bov and I dont have the standard one, the idle was fine until i changed the spark plugs? how do i check the tps voltage? tps is plugged in, and also as for the o2 sensor when driving it barely moves, where can i get one from? is it genuine nissan only? yeah on idle when i look at the laptop it sits at 0.8 and then every now and again it goes down to 0.0 and straight back up to 0.8 and stays there, could the o2 sensor really cause that much fuel comsumption? as for tcs and slip its not the coils because i had them checked out and their all fine, whats the easiest way to check for leaks? ahhh this bloody rain I cant go out and check anything, thanks.
dead o2 sensor would only increase your fuel consumption maybe from 15 to 20l/100kms max
at that fuel consumption there has to be some underlying problem
what temp does the consult software read when the car has been on a while, it should be about 87°c for a neo (or 82 if running an r33 thermostat)
i'd say the main culprit tho would be a loose hose clamp or split joiner on the intake plumbing somewhere
get some start your bastard and spray that on the intake joints as the motor is running, if the idle changes, you have a leak
On the consult its reading at 83-85 degrees, I get my o2 sensor tomorrow, I'm actually going to get a bunch of them as I'm getting them dirt cheap and will pass the savings on to anyone that needs one on this forum without making a dollar off them, I've already sprayed throttle body cleaner on all the joints it all seems ok? Also my tps is reading at 0.45v on idle, is that where it should be? If someone has the Nissan scan tech program I can send you a log of a test drive if you can tell me something about that? Also would cleaning the tps help? Could it be because I sprayed throttle body cleaner into the throttle body cause it to throw junk onto the sensor? I did kind of go crazy with the stuff as the throttle body was a little dirty, I will let use know as soon as I install the o2 sensor and reset the ecu and go for a nice drive to see how it goes, let me know, thanks.
Hey guys ive got another problem, ive got a leak somewhere around the turbo and its whistling alot more and boost is laggier, its kicking in at 4000rpm, would it be the manifold to engine gasket? or the turbo ones? if i get this kit http://www.ebay.com.au/itm/TURBO-GASKET-KIT-SKYLINE-R32-RB20DET-R33-RB25DET-R34-/110598767531?pt=AU_Car_Parts_Accessories&hash=item19c03343ab and replace them, should that be ok? is that the gasket kit i need for my car? let me know asap please, thanks.
You have these existing problems but now modify the vehicle further? Fix problems first and then move on before making it worse to diagnose!
blitz bov - This is venting to atmosphere and you are probably getting reversion which means air backwards through the AFM causing a rich temporary reading causing the backfire and potential stalling. Put the factory BOV back on and make sure its pointing to the turbo (and away from the AFM)
You have an intermittent problem with the TCS/ABS system which the ECU is flagging (and then you clearing) but obviously keeps coming back. More information can be had via a proper Nissan consult II scan tool directly in the TCS/ABS units since ECU consult only reports that something bad has happened.
Once you know the proper problem then you will have more information to diagnose further, but nothing we can do on here to help you further until you dig deeper with that one
Hey thanks for your reply, as for the loud whistle when on boost and when you pop your head next to the turbo you can hear a leak, is that the correct gasket kit that I listed above? Let me know ASAP, thanks.
Well, that's a full set of gaskets. You've got manifold-turbo, turbo-dump, oil drain and also outlet elbow (that's the three 3-bolted ones that you'll only need one size of). This will do the job.
But - wouldn't it be easier to work out which gasket needs replacing and work on buying just that one?
Hey man, well since im going to be doing half the job to replace that 1 gasket, why not just replace them all and them im sweet for another 11 years or so how old the car is haha, thats my drift, that whole kit is $54 shipped or just 1 gasket for $19 so its a win win, so sweet thanks for the answer man I'm going to order them now and change them as soon as i get them, and let you know how i go, thanks.
It's just that it's a pain in the arse to take all that shit off if you don't have to. You can break studs and shit that seriously interfere with putting it back together if you're doing it at home - stuff that would have been fine if left alone.
Don't get me wrong, if you're all gung ho and want to take it apart and put it together with fresh gaskets, go right ahead. If nothing else you'll take the skin off your knuckles, you'll gain experience blah blah - and can sink a beer afterwards.
Hey guys, well there's a problem, hes all the way up the central coast, I'm pretty mechanically minded, now could you guys please help me choose which gasket kit to get from the links I post below I would really greatly appreciate it, also another weird thing happened today, my boost gauge is showing the car at -6psi on idle usually it was around -13-15psi, and I tried another gauge and its the same thing, and it only boosts to 5psi max, i was thinking air leak although wouldn't it still be vacuming the same at -15psi? or do I have 2 shot gauges? I replaced my o2 sensor and so far the fuel economy is really good so far, usually after filling up after 50kms quarter of a tank has gone, now I've done about 55kms or so and the needle has just barely moved so I hope that was the fuel problem, also I have a standard BOV coming in as well so I'll let use know how that goes as well, any help is greatly appreciated in advance, thanks.
http://www.ebay.com.au/itm/SKYLINE-R32-RB20DET-R33-RB25DET-R34-TURBO-GASKET-KIT-/180692473556?pt=AU_Car_Parts_Accessories&hash=item2a121c56d4
or
or
http://www.ebay.com.au/itm/TURBO-GASKET-KIT-SKYLINE-GTR-R32-R33-R34-RB26DETT-/120654815662?pt=AU_Car_Parts_Accessories&hash=item1c179661ae
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
