And have caveman man-legs.
You forgot that part. :P
I go to that gym he's talking about and none of the women look large or muscular. They look atheletic and strong, yes, but theyre powerlifters not body builders.
So yes, replacing squats with a leg press machine or any leg machine is absolutely stupid, but what is more stupid is to think you don't have to do leg press exercises as well.
Uh the gym I go to has no machines at all, just power racks and free weights. Most of the guys in there squat at least 130kg, with quite a few doing 230kg+. There are a couple of world record holders and some of them have never used a leg press in their life. None of them have used one since joining this gym.
  • Replies 158
not talking about power lifters here buddy, talking about the average joe. leg press is an isolation-based exercise
and the average Joe should be squatting not leg pressing, if they're lifting for health & wellbeing not bodybuilding...
I'll finally put my 2c into this lol....only really just started bothering with squats (I know I know....), so this evening pushed out an easy as hell 10 reps @ 100kg. Funny, because when I used to do squats end of last year, 60kg was HARD...now I reckon I'll be on 120kg next leg day for sure!
hey guys,
got a question for some of you who do fairly heavy squats and dead lifts..
do any of you do much core work to help protect your back and spine when it comes to heavy squats and dead lifts?
(and if you do what exercises do you do also sets reps etc)
or do you think that your squats and dead lifts give you all the back and core strength you need to do heavy weights?
deadlifts and squats are two of the best core buliders u can do IMO
if u want to further improve it, avoid using machines and where possible do ur exercises standing up or with no back rest
ie instead of doing seated shoulder press witha bar bell do it standing up etc.... u will generally lift less unsupported though
If u wanna protect ur back, build up slowly and dont go too hard to quick... and if u are performing these exercises and u feel even a slight tweak in ur back FOR GOD SAKE STOP!!...ur only goin to make a small tweak worse and its goin to be alot sorer when u cool down
Edited by GTR_JOEY
cheers for the reply mate :) yer i figure that they already work it alot.. was just looking for more lol. and i hear mixed opinions at times...
i do shoulder press standing already. and dont use any machines at all, as i do my workouts at home, have a squat rack, bench, chin up bar and free weights.
im guessing u dont do other core specific exercises then mate?
yeah sometimes i like to throw in a few core exercises
some are:
knees to elbows (hanging on a chin up bar then curling ur knees to ur elbows)
Leg throws ( lay on the ground with someone standing behind u, grasp theyre ankles and get them to throw ur legs to the ground)
Prone holds combined with medicine ball twists and crunches
theres a million things u could do hey...be creative lol
some are:
overhead squats
superman pushups
weighted planks
hyperextension or GHR (weighted)
ab wheel rollouts
cable twists and variations
pull ups with leg raises (can add dumbbell between feet)
but yeah anything where you pick up heavy shit off the floor and put it above your head is working your core pretty damn hard!
Woodchops and other cable pulling exercises where you are standing up! Don't attach the "machines are bad" stigma to all cable equipment, these exercises target side muscles which are often neglected by traditional workouts and exercises, where the focus is purely on push and pull in front and behind. On the Hollywood front, girls dig obliques ;)
  • 9 months later...
Husky 33 is VERY knowledgable, I'm impressed, Mike and Tolga know, as does Keiran
Stolen S15 (Nick) is a machine, one of the hardest trainers I've ever seen, I have a vid of him running 140m.........with a 140kg barbell on his back, running
Gday Ali, long time no speak
I think Nick has since squatted 250kg, in competition, and Ghosty can rep 2 x bw squats all day
Some pretty strong dudes in here
  • 3 months later...
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
