hey,
so as the topic states i have rounded the filler plug on my gearbox whilst trying to get the lil bastard out.
just wondering if anyone has any ideas as to what i do now?
i read on an old DIY that you can refill the oil through a hole or something near the gear shifter inside the car?
iv had a look and cant see any obvious way of doing this, if anyone has done this successfully where am i ment to be pouring the oil?
thanks for any help...
https://www.sau.com.au/forums/topic/372334-r33-gearbox-oil-change/
hey i just changed my gearbox oil yesterday. tried to take out the gearstick but couldn't. then had to refill at the bottom. does anyone have a step by step tutorial on how to remove gearstick? i heard you need a right angled long plier to remove the stick?
ahh, so you take the shifter right out do you?,
mingy
theres a step by step how to in the DIY forums under installing a short shifter or something like that
ill give it a crack, hopefully my drain plug doesn't round aswell..
on that note my 1/2" drive breaker bar doesn't seem to fit snug in these plugs, any ideas on how to prevent it from rounding them?
Remove the two circlips and it will come off. 1/2 inch works for me, they shouldnt be that tight that it rounds it, just be careful when doing it and if you feel it slip stop.
alright got the shifter out no worries, then got back under to remove the dump plug and..... no bingo! rant.gif
i'm using a 40cm breaker bar WITH half of my garage jack handel on the end giving me a total of around 1.2m worth of breaking power, iv sprayed the crap out of it with Lanox inox
and still just feels like its bending the plug about to round it!!!
any ideas what to do?
the only issue with taking it to a mehchanic is once they get it out they will have to refill it so i cant get it home.
dont wanna know what they will charge me for a few hours labour and use of their shop.. :S
waiting on a new plug now so i can try the chisel... if that still doesnt work for some reason then ill have to take it to a mechanic haha
I had the same problem with my motorbike's sump plug, I tried everything but managed to get it using vice grips + hammer.. had part was getting those vice grips on super tight.
In trying everything, if the vice grips didn't work I was willing to sacrifice a ring spanner by welding it to the sump plug
Did mine yesterday and was tight but with a standard braker it got undone, was not worried about rounding it at all, there was alot of some form of sealant on the plug for sure, as it's only a shallow 1/2 inch plug just make sure the bar is in good and proper and let the guns do the rest of the work
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
