Hey guys,
I wanted to open this thread for a while after a few people brought it up in my other threads. Basically, id like to know what people think of swapping the final drive ratio in my r34 gtr? even 32 and 33
Basically i think the rb26 is too small for a heavy car on the street (not talking on the track where your rpms are always high)
My car is rarely driven and even when im on the freeway, i never really enter 6th gear, 6th seems to be too laggy and the car dosent maintain speed when you reach an incline, need to drop back to 5th.
my query is: what are the pros and cons of swapping?
my gut tells me that: 1st will rev fast, 2nd wont reach 100kph anymore and i will have to change gear more.
also, being a vspec 2, can i even do the swap as it has active lsds - then again, the mines gtr has done it??
ps: im not a mechanic so i may need the pros and gurus here to sugar coat explanations for me.
any replies would be much appreciated and very educational.
-Johnny
https://www.sau.com.au/forums/topic/372956-swapping-final-drive/
3.545FD to 4.111FD is a massive jump.
You'll get to use that 6th gear on freeway. Makes for a better car to drive, much more responsive and torque is readily available.
Downside is obviously the sacrifice in top speed and also slightly less km out of the tank.
This is just based on driving a 4.4FD to 4.9FD Honda 1.8L engine
yeah deano, R32 GTR speed drive is cable straight to the speedo so no electric signal bender will work. if you change to GTS4 diffs (4.375:1) then you should be able to buy the GTS4 speedo drive gear and repalce your standard speedo drive with the GTS4 one. I haven't personally bothered before but will probably do it when I convert my current GTR.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
