Genelle, whereabouts? Trying to think of which school zones it'd be possible to do that in :/
And oi, I'm from south of Wollongong and I'm not an idiot like that.
Now there's one less suspect!!!!
I wonder if police would reveal the number plate if asked.
https://www.sau.com.au/forums/topic/373661-130-in-40-zone/#findComment-5960628
Owen,was on the highway at warilla or barrack heights area.
https://www.sau.com.au/forums/topic/373661-130-in-40-zone/#findComment-5960633
yeah, sister just rang me: 24-25 year old from kanahooka, apparently port kembla? but shellharbour road... hmm. can only think of a handful of schools on shellharbour road. there's the one at port kembla behind westfield, and there's possibly warilla high (not sure if the 40 zone extends to shellharbour road though), and then the odd little one down near shellharbour itself.
either way. cause he's from kanahooka you know he'll just get in another car and drive that, too
https://www.sau.com.au/forums/topic/373661-130-in-40-zone/#findComment-5960650
was probably at the sole college, across the road from ocean beach drive and black butt forrest.
thanks for this thread, i didnt hear about this idiot but i live in shellharbour so im sure ill be pulled over next time im in my liner.
zzzzz
https://www.sau.com.au/forums/topic/373661-130-in-40-zone/#findComment-5961480
He was done in the area Jarrad said.
It's normally an 80 Zone, and seriously, there's NO houses around, and you will NEVER see a kid on that road during school time. Just plenty of moron drivers.
Most people do 60 - 70KM/H through that school zone of a morning. I used to use that road every day during school times, I used to laugh at the amount of people who sped through it, as once a week there would be an unmarked HWP parked near one of the park entries booking people. Although, half the time he didn't care about those doing 60/70... More the idiots who do warp speed.
https://www.sau.com.au/forums/topic/373661-130-in-40-zone/#findComment-5961780
zzz not condoning his actions + doing 130 in a resi zone is stupid but a lot of school zones need to be removed. Especially the ones that are on main roads and have had a pedestrian bridge built or there are fences 6ft tall in the medium strip to stop people from crossing the roads. Also look at removing some on roads near high schools. No offense but i was taught ever since i could walk how to act around a road and how to look right then left then right again. If high schoolers don't know how to act around a road and how to cross a road safely then they should just drop out of school now and focus on their career in the fast food industry.
https://www.sau.com.au/forums/topic/373661-130-in-40-zone/#findComment-5961969
I don't think this is an argument about if school zones are good or not.
For those who don't know, it's a road that is 3 lanes each way, with no driveways in this section (There are further up the road though)
Still, 130 is freaking stupid, it's still 50 over the normal limit.
https://www.sau.com.au/forums/topic/373661-130-in-40-zone/#findComment-5962140
This school is for primary age students, and there aren't fences or bridges there. While I agree that some school zones are a bit too long, I wouldn't say to remove them completely. 40's an awesome cruising speed for the year 12 chicks ;)
SNAP!!!
:banana:
https://www.sau.com.au/forums/topic/373661-130-in-40-zone/#findComment-5962155
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
