  • Replies 195
Almost worth changing over to Tuner class....RWD runner up looks like a good chance there ;)
that said hoping the driver of the commo is not the same Bryce Washington as:
http://www.adradradiatorexperts.com.au/sponsorship.htm
2005 Australian GT Champion, 2005 Porsche Driver’s Challenge champion
something you're not telling? Are you entered?
Depends which evo it is... one of the chaser prep'd evo's did a 1:37 at superlap :P
Look at the first post :P
He is entered, even if their site isn't updated :D
I heard the EVO might not even be ready!
Also ill organise the marquee to be there for us.
Scott has room after talking to him yesterday so that way we won't all get roasted or wet ;)
That's great. Mostly sunny 19 forcast so far.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
