Well I just dont like em, however I wouldnt mind if it only worked with parker lights and not full beam. Would this be difficult to do? Also, will disconnecting the sensor disable the auto lights altogether? If only I had a wiring diagram....
https://www.sau.com.au/forums/topic/374237-automatic-headlights/
Put a relay on the sun sensor that gets its trigger from the parkers.
Parkers are the switch, sun sensor positive wire (whichever really) is the 12v and the output.
Ground is ground.
Thats the easy solution taked care of, CHEERS! :thumbsup:
Now, anyone want to put their hands up for running the auto lights for parkers only??
You could disable the auto lights by not turning them on!!? And why would you want to run with parkers? In this country itis illegal to run on parkers only - i.e. if its dark enough to trigger your auto lights you need your headlights on.
I do a lot of country work and have the parkers on during the day and usually forget to turn them off - which is where the auto would be useful if i bypass the light sensor. What i hate is at night switching in the order of - OFF - AUTO - PARKER - FULL BEAM. This makes the full beam flash as i click through which makes people think im flashing the lights at them, especially the neibours across the road whos bedroom is opposite our driveway
I just prefer not to use it, why can't it be after parker and low beam. Then there is the annoying lights on and off at dusk n dawn. Honestly I think I'm intelligent enough to know when to do things like use my headlights or windscreen wipes, I guess I'm old school where I prefer to drive the car and not have it do all the thinking for me.
Quick Qs, regarding M35s...
Seperate to the Auto Headlights.... Are the dash lights auto dimming too? Like all this week, with my headlights off, at around 5:30pm on way home from work, not dark but not bright sunny either, the aircon display and dash go dim...
Yep, the light sensor triggers the "night" level when I go under a bridge.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
