  • Replies 44
Posted Images
http://www.ebay.com....=item20bb013d31
i got it of a mate for a birthday gift, but they go for $150 as the link.
yeh i mounted it myself, just got some bendy mounting brackets from Bunnings and i was set. i installed jethros too.no more than half a litre at most.
Trans oil should have Thermostat,
as it runs hotter then Engine oils.
so its great putting bigger cooler on but trans runs at about 100 too 110 degs,
if you can find Mazada FD cooler it has built in thermostat ,you may want too look at Filter kits for trans as it will prolong trans oil life.
post-36964-0-75811100-1313646160_thumb.jpg,
http://www.summitrac...arts/DER-13090/
good luck,
Chuckie this is exactly what I want. Can you still pick them up new from Mazda? Or do you need to find a second hand unit?
I got mine 2nd hand,both in good nick too,
i run one on Trans with Filter kit ,
one on Engine oil with remote + stock filter,
has made a big difference to oil colour as before it was not red as it should be,
iam about to do Trans oil sample so i shall post up what i find out,:thumbsup:
any filter will help oil life ,my steering cooler is a big winner as its red still ,before i would change oil in top tank every week & it would be Black.
I had the 6cyl version of the PWR trans cooler (like the one Aaron showed).
Mounted it as you can see below... until I upgraded the intercooler.
I reckon Chuckie's suggestion is pretty good although there have been no ill-effects with a large trans cooler on M35's.
good luck,
best advice ever chuckie!
and idea on the physical size of that transmission cooler? it appears to have the right fittings etc to plumb it straight in
Been hanging to get mine up2 MVs.. Turbo tune said Its the biggest trans cooler they have seen .. "u could use it as a front mount" lol
Hada get it relocated when I put da FMIC on.. sits drivers side behind the body kit factory holes either side on stock S2 front bar bar.
Had shift problem b4 nistune and tune.. Better then all good now... But Really wnt MVs to have a look at the whole set up and find out what was done!
Cheapest I can find for an RX8 oil cooler - http://www.mazdatrix.com/getprice.asp?partnum=14-700D-N3H1
Thought I'd ask SK about his thoughts on it. His brief response was "There is no such thing as too cold transmission fluid."
I don't know what to believe/think. In Australia does it really get cold enough for this to be a concern?
Cheapest I can find for an RX8 oil cooler - http://www.mazdatrix...um=14-700D-N3H1
given I can put my hand on mone and almost get a burn off it - yes it is needed and I do agree with teh above statement. heat kills these things - I have a $4500 bill to prove it.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
