Sucks with the clutch mang. I have had an excedy cushioned button in mine since the swap. No issues whatsoever. Must be a hit and miss dealio. I wanted to organise a night at the drags soon but guess u wont be heading out. an always come watch the rest of us have fun.
  • 3 weeks later...
VL box and custom clutch on its way, got new plates will upload pics soon
and to the guy in the van this morning, sorry im not much of a morning person but yeah i work at Duncan foster (link below) pm me for details on what you want to do to your r32 :)
just read the whole thread. props for doing what many people have talked about and never done. nicely put together engine. If it were me going for power and torque i probably would have made the CR around 11.5:1 and tuned it for E85.. would have been nuts then :D
Yeah need to get in car videos/ bumper videos sometime soon
ok well old gear box is out, clutch plate 4/5 still good,
pressure plate fingers are badly worn,
the thrust bearing (appears to be the culprit) is fairly chewed out on the inner surface that connects to the input shaft. It shows signs of metal rubbing on metal and seizing on the input shaft
Single piece tail shaft & MX7 box next to old bits
Nothing new, still waiting on clutch to turn up
I decided to do some maths
.........RB30/20........MX7/VLT.....Difference with 3.89:1 diff............Difference with 4.11:1 diff (coming soon)
1st.....3.321:1.........3.580:1.........7.3% Increase in acceleration........12.5% Increase in acceleration
2nd....1.901:1.........2.077:1.........8.5% Increase in acceleration........13.8% Increase in acceleration
3rd.....1.308:1.........1.369:1.........4% Increase in acceleration.............9.3% Increase in acceleration
4th.....1.000:1.........1.000:1.........--------------------------------------..............5.3% Increase in acceleration
5th.....0.759:1.........0.759:1.........1% Decrease in aceeleration............4.3% Increase in acceleration
This is a bit misleading because the gear will be over quicker, hence you'll be in the taller gear sooner. If you were to graph the acceleration of both diffs overlapping you'd see on average the acceleration isn't improved greatly when looking at a large spread of kph. In just first gear etc it will be a large increase though.
Yup i was, speak to sams performance, he builds some really high powered LS motors bit expect atleast an 18 month long cue :P
Yeah, the 4.11 diff will only give a 5.3% increase on paper compared to the 3.89, but looks like a bigger increase if you add the vlt ratio and compare it to the standard gears and 3.89 diff
And yeah taller gears = more acceleration and less top speed
but this is all on paper, will chuck it on a dyno afterwards to see what difference the 4.11 made on acceleration
flywheel before being ground
Flywheel after its been ground and ready for balancing
flywheel being spun up to check for balancing
New cushion button clutch plate and modified pressure plate
Blancing Pressure Plate
Spinning up pressure plate
thats all for now
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
