Garrett GT3071R Kit forRB20/25
Product Information:
480HP Kit Includes
  • Garrett GT3071R-20 (700382-5020)
  • RB Turbine Housing (RB25-GT28)
  • Hi-Flow of Turbine Housing
  • RB Water/ Oil Kit
  • Silicon Reducer
  • Dump Stud Kit
  • Silicon Joiner
  • Hose Clamps
  • Spacer Plate
  • Gasket Kit
  • T/E Clamp Kit
  • Actuator 16psi
  • Actuator Bracket and Rod
  • RB Intake Pipe and Outlet Hose Kit
Price: $2638.00 inc GST
This kit?
-20 cart is not a GTX
Good price then, GTX's are typically going for a few hundred more than their GT cousins
Edit, while i'm in the thread:
As another rb25/3071 owner who had a hell of a lot of trouble with boost control in a Garrett IW .63 housing i would strongly recommend a .82 with a GTX if you are staying internal gate.
I would probably still go a .63 if i was doing an external gate setup in either GT or GTX 3071
Edited by badhairdave
Did you try Street to Track? Thats where I ended up getting mine, he gets bloody good prices from Garrett Aus or ATP in the US.
I agree, run the .82 rear. I have the 1.06 and im very pleased with the way it comes on but the .82 is the pick.
Uncontrollable boost through the midrange and top end with the .63 housing
Enlarged the wastegate port and flap as much as possible to try and bypass more. It was partially successful in that it could now limit boost to 1.2bar through the midrange but would actually blow open up top. I concluded that the fairly large area of the flap and highish manifold prssure was simply able to apply too much force to the flap for the small actuator.
So next was going to be a big can actuator to replace the small garrett one but instead i crashed the car into the tyres at a race track...pretty confident that it would have done the job, but spending an extra 500 to mod the housing on a brand new turbo and buy a new actuator is a bit much.
Was going to upload a photo of the modded housing by photobucket is being a bitch
No i didnt try them scotty thought the price that i got was reasonable so i ran with it and unfortunately ive already the .63 rear housing so im just gunna roll with the punches and see how it all goes still waiting on delivery though
Just thought id post a pic up of my GTX3071 next to a size 14 nikes and my hairy leg lol
Hey Mick_o, what rear housing have you got? And can you please take and post a pic of that small plate with turbo part number?
And that doesn't look like big can WG actuator.
Edited by Legionnaire
Nice shoes man, how much? :P
Now hurry up and get the turbo on the car and post results :)
Haha they were $220 mate i think and trust me im hangin to get it done not this weekend but the next me n jez are bolting her up and filling my tank up with e85! Yay!
I think its the .63 rear bolts up to standard dump ill post a pic up tomorrow but its a sonic rear housing and the badge on the housing is 803712-5001S( in small numbers) and below is 112101-11 (in bigger letters) can anybody tell me what size it is?
numbers not letters lol im tired big week :( 88hrs of work
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
