Good stuff.... :banana:
the internets he says shes says can drive you crazy...I went to the extent of buying a new turbo for mine cause for the last 4 months I havent been able to drive it.. So I sit here reading stuff to kill time and on paper full boost @ 3600 and 235kw, its not so crash hot..
Got it up and running today drove it around a bit, give it a few clutch kicks and i was having a ball, so much so i couldnt care less about the new turbo atm I just wanna drive..
just bolt it up get it tuned and I bet you will love it..then 1 of 2 things will happen
1.. you will realize it wasnt worth all the headache and expense and give up on it..
2..you will freaking love it, the bug will bite and you will start a list to mod more shit..
Busy training with air for other purposes today .
A std BB type GT30 turbine measures around 59.9 by 54.9mm inducer and exducer .
The cropped ones from memory are 56.4 by 51.6mm (84 TRIM) OR 56.4 by 53.6mm (90 trim) .
Your calls , my preference is for Garrett or HKS GT30 "T3" flanged GT30 turbine housings . The HKS GT Pro S ones need a bit more work to make the dump pipe and if you particularly wanted one of their different A/R ratios its probably worth it .
I'm not sure what size because there isn't a lot of feedback with these GTX compressor wheels .
A .
Heyyyyy?
To clarify, you gibberish speaking bag lady, your talking about your existing setup? Not a 20g result. Yes?
Heyyyyy?
haha..thought that might stir ya... ;)
thats my exsisting setup yes...its lame on paper but its still great fun to drive..
Ok ok u guys have talked me into getting the .82 garrett housing lol!!!! ive spoken to MTQ today and they are gunna let me exchange my sonic housing for the garrett unit tomorrow arvo and they have a dump pipe as well so its gunna cost me another $500 to swap housings and get a new dump pipe.......
So will the little 14psi actuator that i have pictured in here be up to the task or is that somethin else ill need to look into?????
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
