Don't waste your time mick, all you'll be doing is increasing the length of pipe for no noticeable reduction in intake temps.
The air is moving too quickly to pick up much radiant heat off the rocker covers as mentioned above.
As for your leak; if you have any unreinforced rubber joiners then get rid of them. They stretch and allow the air to squeeze out under the hose clamp at high pressure.
I have replaced all the hoses with triple ply reinforced silicone hoses Dave and ive got new hose clamps recommended by yavus they are only bout 8mm wide so they should bite down good on the silicone hoses and since ive replaced the wafer thin alloy pipework with stainless i can nip up the hose clamps that lil bit tighter without crushing the pipe
Haha yeah thats them mate im sure that there is better but they should do the job tho
haha they have gotten you onto the wurth clamps.. I dont mind them but wouldn't call them the 'ducks guts' as they do
SHHHHHWIING! Hahaha thanks Jase just gotta get a longer piece of silicone hose for the boost controller line and put it all back together properly and its zoom zoom time :merli:
lol nice pin, sexy as always :action-smiley-069:
Unreal job on the pipes, looks fantastic! You should make up some rb25 3" metal intake pipes with all the factory connections that bolts up to the factory airbox! Plenty of people like me will buy one. :)
Plenty of people like me can make one. :)
Thanks Harey im planning on making few kits up to sell just need a standard box so i can fab up some pipes
Yeah mate gunna be there Friday arvo sometime gotta call the boys bout lunchtime to see what time Yavuz can finish my tune off their new dyno is due in sometime Friday and cheers its all finished now so come have a chat mate & check my handy work out in the flesh if your floating around
So this will be at Unigroup on Friday? Sweet I'll be there too - have to check out it out in person, looks really good so far!
Yeah they are setting up a new shop in Windsor too which is good for me being a Hawkesbury native :thumbsup:
Oh yeah, I knew that.
I should be out there on Friday also, so It will be good to put a name to a face.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
