It is an interesting result, falls over quite early for a cammed RB25 with a GT3076R though - wonder if there is a restriction somewhere or something. I would have expected a bit more, but I guess we have fairly few internally gated/stock manifold E85 results to work from.
I wonder where you've seen that.
The GTX3582 AR63 isn't a good choise. It produce exact the same power as a GTX3076r but, came on 500rpm later! A GTX3582 Ar 0.63 doesn't make sense because the turbine housing is the limited factor! And with a Ar 0,82 it is very much to laggy. I say that with experience, because i've had a gt3582 Ar0.82 on my Gts-t with a external screemer pipe :-) ther's nothing to 5k rpm and than "bangggg!!" funny but not very useful.
Is there nobody who ha experience with a gzx3076r on rb25det?
I have gtx3076 .82 on my rb25...
  • 1 month later...
The RPM is calculated though, its usually not accurate from what I have seen, how can you know every car's ratios anyway? If you can't work it out from the graph i'm sure someone will have a guess for you, without seeing the sheet I can say it would probably come on hard around 4k.
My tune today didn't pan out, speed cut and a slipping lock up clutch ruined my chances of a good result with the 71. I will be back on the weekend with the SLD back in place hoping for 350kw.
The gtx3076r is similar in spool, if not a small margin worse, than the gt. The gtx really only comes to life once you start throwing lots of psi at it. Although.. Im sure a true twin scroll housing+manifold would bring the spool back to baseline.
Any luck with the tune Scott?
I was seeing over 300kw in 4th at speed cut which I guess was around 5000 revs. Once I wire the SLD and get rid of speed cut again I will be able to see the outcome of my fine tuning. The MAC wastegate solenoid is working a treat now, it held a flat 25psi from what I could see. I will ramp it up on the weekend during the next run.
It has external gate, AVCR , 256cams, cam gear, maybe a 50/50 ethanol blend
id be happy with near 200kw at 4000rpm with 18-20psi
Why 50/50? how far away is Warwick from you? (or is there a Caltex up there?) You will see better gains from just running United e90 with none of the cold start issues we see down here...
You should come close, perhaps around 4200 revs? That's my guess.
well im doing all this on a tight arse budget and getting impatient, some parts like the HD clutch, walbro fuel pump, and now rear muffler with silencer may fail before it reaches 300kw
So i guess for now ill have to see what happens on the dyno, im thinking even 280 would be great,
50/50 blend is another cheaper option.
Edited by SliverS2
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
