It is an interesting result, falls over quite early for a cammed RB25 with a GT3076R though - wonder if there is a restriction somewhere or something. I would have expected a bit more, but I guess we have fairly few internally gated/stock manifold E85 results to work from.
I wonder where you've seen that.
The GTX3582 AR63 isn't a good choise. It produce exact the same power as a GTX3076r but, came on 500rpm later! A GTX3582 Ar 0.63 doesn't make sense because the turbine housing is the limited factor! And with a Ar 0,82 it is very much to laggy. I say that with experience, because i've had a gt3582 Ar0.82 on my Gts-t with a external screemer pipe :-) ther's nothing to 5k rpm and than "bangggg!!" funny but not very useful.
Is there nobody who ha experience with a gzx3076r on rb25det?
I have gtx3076 .82 on my rb25...
  • 1 month later...
The RPM is calculated though, its usually not accurate from what I have seen, how can you know every car's ratios anyway? If you can't work it out from the graph i'm sure someone will have a guess for you, without seeing the sheet I can say it would probably come on hard around 4k.
My tune today didn't pan out, speed cut and a slipping lock up clutch ruined my chances of a good result with the 71. I will be back on the weekend with the SLD back in place hoping for 350kw.
The gtx3076r is similar in spool, if not a small margin worse, than the gt. The gtx really only comes to life once you start throwing lots of psi at it. Although.. Im sure a true twin scroll housing+manifold would bring the spool back to baseline.
Any luck with the tune Scott?
I was seeing over 300kw in 4th at speed cut which I guess was around 5000 revs. Once I wire the SLD and get rid of speed cut again I will be able to see the outcome of my fine tuning. The MAC wastegate solenoid is working a treat now, it held a flat 25psi from what I could see. I will ramp it up on the weekend during the next run.
It has external gate, AVCR , 256cams, cam gear, maybe a 50/50 ethanol blend
id be happy with near 200kw at 4000rpm with 18-20psi
Why 50/50? how far away is Warwick from you? (or is there a Caltex up there?) You will see better gains from just running United e90 with none of the cold start issues we see down here...
You should come close, perhaps around 4200 revs? That's my guess.
well im doing all this on a tight arse budget and getting impatient, some parts like the HD clutch, walbro fuel pump, and now rear muffler with silencer may fail before it reaches 300kw
So i guess for now ill have to see what happens on the dyno, im thinking even 280 would be great,
50/50 blend is another cheaper option.
Edited by SliverS2
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
