I WD-40 THE HINGE ON THE TURBO & IN ''N' WHEN I ACCELERATE THE BOOST+10. BUT BEFORE IT GOES TO 0. WHATS WRONG WITH THE BOOST WHICH WAY IS TI SUPPOSE TO WORK.
NEED SOME HELP :worship:
What is this, a random phrase generator?
Not every set of put together randomly picked car related words makes sense.
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012476
His socks are probably still wet as he got off the boat into a skyline. With that said, I am guessing he squirted WD40 on wastegate flap and saying something about in neutral it goes to +10 which is probably wrong considering the nissan gauge is +7-7. You will most likely never create positive boost on the stock turbo in neutral. Your gauge is probably shit. + is positive boost - is vacuum, or negative boost if you wish.
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012518
i dont know all the parts of the car especialy turbos .ive got a boost controler. thats how it went +10 in ''n' first time it didnt do it again.the question is why would the car do that.
PRIVILEGED PEOPLE WITH R33 .$12.500 my life acomplishment
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012600
Ok I get it now. The Sarge is correct. Now that I've read it a few more times It does make sense.
You won't create any noticeable positive pressure while in 'N' because of the lack of load on the engine. Make sure your gauge is accurate by checking against another one
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012663
if your some kind of mechanic ,doesn't mean u can drive .it means u work 4 $18h :thumbsup:
Maybe where you come from pal. In Australia being a mechanic means not only can you drive but you get paid $30 an hour upwards.
http://www.seek.com.au/Job/heavy-vehicle-diesel-mechanic-wa/in/perth-perth/20651329
Edited by Room42
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012666
exactly and they wonder why theres a skills shortage..
I found a job the other day fixing pallets, was shift work but paid over 1000$ a week..I know blokes earning twice that pushing a broom at the desal plant..
Its crazy but truth is by giving people with no qualifications money often means they will spend it with qualified people which lets qualified people can charge what they likeand the people paying dont care cause they make heaps of money for nothing.....its the circle of life
at the end of the day though the broom pusher is more expendable than a qualified mehanic.If there was a war the broom pusher will be on the frontline getting shot at while the mechanic will still be fixig cars ,or tanks..
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012728
Who in their right mind would work for $19 an hour if they were a qualified mechanic? You get paid more packing shelves at the local supermarket.
Exactly....but would I be happy packing shelves at a local supermarket? Hell no.
Obviously you have the potential to earn more with a busy employer or a large company in need but Mechs are the lowest paid trade in the world
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012873
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
