  • Replies 71
How much are these 200l drums of fuel? Must be better then pump price buying bulk ect, keen for some 98 ron
around double the price, definately not cheaper but drums is the only way to get e85 in some areas and its the only way to get the race e85
price has just gone up to $550 a drum.
I've spent a heap of $$$ on an engine build and i'm happy to spend the extra dollars to buy sucrogen for a little while to be guaranteed the same octane/quality of fuel every time. in my opinion it's especially important during the testing/tuning phase otherwise it becomes another variable.
I'm sure spending this amount on fuel is going to sh*t me soon, but for now i just put it down to part of the expense of building a big hp motor.
Edited by tk80
And then you'll go back to the normal pump stuff once it's tuned/tested or you talking generally???
Confused :mellow:
I mean ye the Sucrogen stuff is great, but then so is the price. At least the owner was funny when he got on here and started abusing people. Good for a laugh.
Yes, i can see a time where i'll be buying pump e85. hopefully the consistency will improve as i've heard of a few bad batches from rozelle. Having said that, the tuner has told me as long as the octane is above 105 then the engine will be safe.
pump e85 is not much different, if at all to drum apart from the price... just saying.
have done back to back testing with both fuels. on dynos.. no difference. the ONLY time you may have an issue is if youre tuning e85 to the absolute limit. which you shouldnt be anyway
ah yes, that douche bag... i think all our cars should have blown up by now or something should have rusted through etc etc *insert scare tactic to justify drum price*...
must go down to United soon to check what E% their E85 is... i'm guessing it'll be around E90 like last time they had it pre-floods - even more powah! :D
Sorry for the off topic, but I'm curious how you all can be happy to pay so much for fuel, like I pay $1.60 a litre for bp 98 octane, you all pay over $2.50 per litre. Is it really worth it?
Oh I thought I read up further that it's $550 for a 200litre drum.
What's your economy like. I get 400-450km from 60litres.
Just had a look and the closest and only e85 servo is a caltex 50 km from home.
Edited by lilcrash
A lil off topic my car was tuned on caltex eflex just wondering if any of u boys notice a power difference from uniteds e85 and the caltex e85?
I have been filling at United for the last 3 tanks, its more expensive at 10c less than unleaded and then I need to put a little 98 in also to drop the ethanol percentage until I get a tune. It definitely smells better though. I will let you know when I get it back on the dyno.
It could have possibly saved your engine though, at 20c less than unleaded it works out to around the same price as 98 to run in my car.
385rwkw on eflex, 400rwkw on E85
eflex may have been mid 60's though at the time.
that's what i was thinking scotty, get some United and just drop in a little 98 if it's like E90 until i get a touch-up - just bring the laptop with me to get the E% reading
although, the wideband should richen things up to the target AFR's in normal cruising even if it's E90
Ye sorry you've sorta missed a "in" joke from a few years back.
Basically the owner of Sucrogen got on here being a ripe tawt, saying pump E85 is a waste of time.
So that you should buy "his" stuff as it's "so much better".
I mean no doubt it is, but at almost double the price of from the local bowser... Not really viable for anyone with a car that gets used regularly. Plus you then needed somewhere to store said drums...
Have a read if you want a laugh: Click Me
Didn't you get the display Daniel?
didn't see the need really... did the baseline E85 tune from a drum of Powerplus to get an exact baseline (which it was, bang on E85), did the 98 and that's it. I mean, i'm not going to change anything depending on the E%, Trent has set that all up and i ain't going to touch that. So constantly seeing the E% would be interesting purely from a curiosity point of view, but for me, not worth the $$ especially when i can just plug the laptop in if i really needed to know (which i will when i get some United)
In hind sight, what i should have done and what people should do if setting up flex fuel is to do the 98 tune and a baseline E100 tune. IMO that's obviously going to cover all the variants.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
