Thanks man.
Mechanical sympathy plays a big part I think. And if the motor goes, then that's that. Ill just get another motor down the line. But that will be a whole new debacle haha.
I am glad you are going with -9's. They are great. :P
I was very lucky with the headlights. One of those once in a lifetime opportunities. Bought them brand new off a guy who works for import monster for half the price.
I also see that I dont have my 1/4 mile PB up on here 11.2 @ 127mph.
http://vid1040.photobucket.com/albums/b406/jacquesvd/Sequence01_1_zps5c9dfec4.mp4
And there will be more videos of hopefully a still running gtr next week :)
Nice video man - I'll have to put down a decent time myself!
You wouldn't happen to be on that GTR Owners Club page?
-9's for the win btw! I just finished building a motor for my set - they really are an awesome turbo!
Do you mean that facebook page? I do believe I'm on there haha. Why's that?
Built motor would be the goods. I'd probably try and see where they run out of puff. I reckon you could get maybe 23/24 psi out of them. That would be some nice power.
Will push mine next year after the engine refresh and new e85 setup ;)
-9s ftw hahaha
Will have to come track with us next year man ;)
Hahaha you will see them I may even start a build thread if I can be bothered
Will be over 360kw I'm sure by how much who knows more looking for more mid range punch for track
Screw it will instruct tuner to max them hahaha just for the efames lol
Yeh that would be the page ;)
And yes, as for power levels everything under 500hp is safe for street use...so I've been told, but I personally will be capping mine at 450hp or so which seems to be the max for these -9 turbos anway. And that's also keeping track work in mind which I dare say you're pretty keen on? We've all probably heard of those who get away with 600hp on the stock motor...but I wouldn't push a 20 year old uncracked motor that far! You will be bragging for a couple days and then BOOM you will be nicely embarrassed haha
The first thing that goes under higher power are the rod end bolts. (so I was sure to throw a set of those in as well)
Nick is a track fiend. When his car wants to play the game.
Besides, I don't run high boost on the track, low boost is much better for it. And I run a slightly richer tune.
I remember this one guy coming around saying he had 360 or was it 380kw on 9's. Hard to believe If you can't back it up.
I reckon 360 is definitely possible with nines. Couple extra psi and the midrange would be intense. It's all about the power under the curve
Tom my engine is built so I thrash it hahaha run 20-22psi on 98 with my -9s with 350kw
Mainly used on the track these days
Engine coming out for a refresh after a random lean out I'm trying to figure out plus some extra little bits and pieces which will make it even faster on track ;)
All about that response
  • Like 1
Yeh I've just finished building mine...I'm aiming for the 330kw mark with my -9's. As soon as she's tuned up I want to be out on those tracks as often as I can hehe and yes, response is everything! 1500kg car, 2.6L engine...you need that thing to come on properly and soon! ;)
Loving the -9s banter! I also have a set and best thing I ever did was go them over the -5's.
I get 20psi by a little over 4K and makes 470hp. Thats with cams swung hard for response, reckon could easy get 500hp from them on same boost if top end was the goal (e85).
Im in the same boat as you man, good healthy stock internals and pulled sump for RIPS extension and billet gears to try make the stock bottom last.
Like you said its a bit of a lottery, but a good tune and ecu along with mechanical sympathy you should be good.
Another plus on -9s is can set limiter lower, 7500 is high as mine goes as turbos run out of breath above it.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
