That's a serious lame excuse there.. you don't do any hard labor for you to be tired. You probably park your fat ass on a chair all day and call that work.
I used to work in a courier depot when i was a full time student 6-7 years ago (round your age), hard labor carrying boxes and stack them up neatly in a semi trailer under the intense 5pm 35-40 degree heat and still had the energy and will to do a 1.5hrs of hard gym pumping session before i headed home. Was cut up like fuark too..
These days i do gym before i head to bed.. best way to sleep.
you are right. reading that probably makes me realise it too, it probably is the reason that birds said below
I know a lot of people who say this and often I feel the same way too, but they all agree that once they are actually at the gym they have no trouble getting through it all...it's the thought of having to do it that turns one off actually travelling there in the first place. So if you can find some way to force yourself to drive there, even with the thought that you'll do bugger all once you're actually there, you should be fine. Some people go to the gym with friends because that motivates them to travel there...
But im up early enough to go. i just roll around in bed until I have to get up..
I just like having my evenings to myself to laze around i think im just wondering. will going to the gym in the morning screw you for the entire day?
Sorry probably worded my statement wrong. My issue/argument was more at the director in preparation for the client meeting.
Shit was instense but of course walking into the client meeting I put on my
Poker face is heavily needed in my role too. especially with meetings with busines operations
That is inches and I am also a 33...but usually have to settle for a tight 32 or a belted 34 -_-
Same here. If I wear 32 suited pants my balls feel squished when I sit down.
But 34 is too loose.
The guy who suited me up said I'm a 32. Maybe he just wanted to see my ass and balls.
Edited by blah_blah
Yeh 32 is a bit tight in the sack region, especially when you sit down and you got a ball chillin in plain sight
Sam quotes on iPhone
Just checked my metre fold ruler which also have inches on other side, I'm 34-36 inches so ideally I'd like 35" but you'd have to choose either 34 or 36...
Let us start a 33 club...
We can all drive R33 Skylines...
Sorry Tony.
I think the moral of the story is SAU people have bigger balls proportionately to their legs and hips
There's mentally tiring jobs and physically tiring I'd rather physically these days kunce doing ya head in all day and u gotta take it home with ya to.
Not lookin down on hard labour but u go u work u get paid go home care free
http://www.heraldsun.com.au/business/petrol-jumps-almost-20-cents-per-litre-overnight/story-fn7j19iv-1226166354321
Damn I'm on empty and need to fill up tonight
"Petrol prices soared from $1.35 a litre yesterday afternoon to $1.54 across Melbourne today"
your right, but people will also see that as an excuse.
i take my work home as well.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
