You talking about mine? or? well it hasn't.. so dunno where your getting your facts from
Boot is not alligned, (there is no mouting leway for a bootlid, only thing to cause it from being missalisgned is a nice bang in the rear)
Front quarter panel paint does not 100% match the rest of the car
Not saying you did it to the car, just saying it was 100% smashed some point in its life
The boot is aligned.. paint has been blended at rear quarter yes but that was from getting keyed
and wasnt yours in a accident when it was white? lol
edit: and cass's - maybe people just like hitting white 33s? who knows..
yea it was... but my bootlid is alligned with the body :P i remember being abkle to stick all my fingers under your bootlid where it should connect with the Skyline garnish (on the left side if i remember correctly)
Most jap imports have been f**ked in some way neways
His even got 4wd spec clearance like you.
I wanna see your car slammed on the floor kris.f**k the law and driveways. :P
Buy it so you can be P-plater version of Kris... LOL
Fk no, that civic does not look as good as cr33m... LOL
Edited by PENGUYEN
U havent seen my driveway, people that have seen understand LOL
I wouldnt have a kit at all if i lowered it, would be left on the ground
Alex, what happened to Jeep thing?
Don't really need a 4wd if I dont have skyline cos nothing to tow still like em but yeh
GTFO off this forum man, go join a ford forum. You can share your boat pictures there
So uptight about fords what's wrong they beat ya in the traffic light grand prix?
Best sound ever skip the guy waffling
http://youtube.com/index?desktop_uri=%2F&gl=AU#/watch?v=lDAChIpBsY4
430rwkws why not...
http://youtube.com/index?desktop_uri=%2F&gl=AU#/watch?v=3Iwejcy808s
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
