What the f**k. I don't remember this lols.
Im certain my friend took my phone because he was using it to message someone.
hmm
bad idea letting your mates touch your phone...
hmm
Lol.
Updated my iPhone to ios5, now I can't download anything from the AppStore. Keeps saying my card is declined when I know there's cash in it. Few other peeps are getting this too. Anyone know how to fix? Wash it with water perhaps?
F*** updating iPhone software, I've kept mine the way it was since I bought the thing...not a single problem. Everyone elses seems to be running slow as shit, enjoy.
Negs, more than enough money in it. There's a credit loop in the app store, all correct info bounces back. Heaps of people are copping it. Ffs
bullshit moh. u just have no money.
didnt know under age prostichutes would be that expensive
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
