Up to page 12. I'll give it 'til midnight.
All the best.
Running on 4 hours sleep. Scraped the paint off my front left rim. Fml.
Gonna powder coat them when I get another set
Sell them and get something that looks better, and paint it different colour that stand out.
Thinking of snacks in bed. F*ck it, I can. No-one here to be judging me :)
Liking the living in your own house?
I sympathise. Was absolutely wrecked last week after moving for 5 solid days with barely any sleep. Went to an empty shopping centre in the morning, wheel arch and flare met concrete pole. I've never done anything like that before :( cbf getting it fixed right now.
Yeah loving it, very quiet complex of 24 units. My house is still relatively empty but I'm slowing personalising it with my weirdness. All but one neighbour has completely ignored my existance.
They so he has traction while he's trying to lose the cops he thinks will defect him.
HAHAHA
Lol should see mine when I'm up it.. if you're behind it, good luck seeing anything lol
haha yeah i know what you mean :P
f**k WHERE ARE ALL THESE DODGY RWC GUYS WHEN I NEED THEM
haha u2 tried to charge me the full amount again cause we were one day late for the rwc because the brakes hadnt arrived
luckly they gave me the 2nd time price in the end.... shifty asians
What is this?
I can't even....
Must be running spacers on the 33 looks good though
hmmm looks tlike the quarters are different, or could be the shadow?
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
