Up to page 12. I'll give it 'til midnight.
All the best.
Running on 4 hours sleep. Scraped the paint off my front left rim. Fml.
Gonna powder coat them when I get another set
Sell them and get something that looks better, and paint it different colour that stand out.
Thinking of snacks in bed. F*ck it, I can. No-one here to be judging me :)
Liking the living in your own house?
I sympathise. Was absolutely wrecked last week after moving for 5 solid days with barely any sleep. Went to an empty shopping centre in the morning, wheel arch and flare met concrete pole. I've never done anything like that before :( cbf getting it fixed right now.
Yeah loving it, very quiet complex of 24 units. My house is still relatively empty but I'm slowing personalising it with my weirdness. All but one neighbour has completely ignored my existance.
They so he has traction while he's trying to lose the cops he thinks will defect him.
HAHAHA
Lol should see mine when I'm up it.. if you're behind it, good luck seeing anything lol
haha yeah i know what you mean :P
f**k WHERE ARE ALL THESE DODGY RWC GUYS WHEN I NEED THEM
haha u2 tried to charge me the full amount again cause we were one day late for the rwc because the brakes hadnt arrived
luckly they gave me the 2nd time price in the end.... shifty asians
What is this?
I can't even....
Must be running spacers on the 33 looks good though
hmmm looks tlike the quarters are different, or could be the shadow?
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
