That's if you don't count today or Friday, = 3 days.
Btw, for sale, single bed from Friday to Sunday.
Goulburn valleys motor village. $60 dorra
might be interested ..why you not staying
good work man. doesnt it ive you reason to just leave it and avoid problems? lol
Yes and no! It will be higher than it was for track purpose... 2-way, exhaust, steering wheel are all going back in this week
At the moment it sits as high as Alex's car haha
Not really.
Was curious cause if you do lower your 34, it really shouldn't sit that low and it'll well within legal height.
The problem with my car is that the exhaust its really low. Came like that from the land of the rising sun.
At the moment I would say the gap between the tyre and guard is about 5cm just to clear the 100mm clearance....
Change your exhaust brah.
Sell your current exhaust and give or take $100, get a better fitting exhaust.
Have thought about it, but don't want to spend anymore on the car than I have to I guess. Also was getting pretty bad wear on the inside on the tyre when it was lowered and is my daily driver.
At one stage I be mirin those racepace exhausts. Then I saw the price tag and cried.
I feel you meng.. but not in a priest way
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
