That's if you don't count today or Friday, = 3 days.
Btw, for sale, single bed from Friday to Sunday.
Goulburn valleys motor village. $60 dorra
might be interested ..why you not staying
good work man. doesnt it ive you reason to just leave it and avoid problems? lol
Yes and no! It will be higher than it was for track purpose... 2-way, exhaust, steering wheel are all going back in this week
At the moment it sits as high as Alex's car haha
Not really.
Was curious cause if you do lower your 34, it really shouldn't sit that low and it'll well within legal height.
The problem with my car is that the exhaust its really low. Came like that from the land of the rising sun.
At the moment I would say the gap between the tyre and guard is about 5cm just to clear the 100mm clearance....
Change your exhaust brah.
Sell your current exhaust and give or take $100, get a better fitting exhaust.
Have thought about it, but don't want to spend anymore on the car than I have to I guess. Also was getting pretty bad wear on the inside on the tyre when it was lowered and is my daily driver.
At one stage I be mirin those racepace exhausts. Then I saw the price tag and cried.
I feel you meng.. but not in a priest way
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
