Council wants a guy to get rid of 10 Japanese sport cars that are across his resoviour house property.
Spotted a few r34 gtt's, r33's Silvia's etc....
All registered or more like not registered?
And rich kent.
Grant, is this the 'sell your GTR week?'
Kinda, but won't do this week, need new indicators as I broke orange ones d'oh!
Still need to mount the plates into the bumper.
Hmmm is it near Northland shopping centre? I know of an importer there and its junky as fuck
most cars have been there for years cause they are shit as too
i'd tell em to get f**ked.
And rich kent.
Not sure it was just a 10sec preview to tommorow night's 6p.m news
Think he was showing the reporter under the bonnet of one of the R34's.
Don't get home from work by that time but am curious if they paint him in a bad light or not. Becuase if he has that many imports he must be a hoon...
i want to sell my car, moving my details to my uncles in perth, going for my wa license and buying another turbo... if it wasnt that much of a head f**k i would have done it in a flash
damn you ric :( i wants power now
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
