My missus would be pissed if I didn't take her, can't say I'm wrapped I find all car related things are man interests for the most part so why she wants to attend I don't know
I mean I dont go for coffee with the girls or shopping or nail shop
Give it a few moths Dezz ya won't want her round so often lol
Lol, my mrs is easier to spend time with than my mates...
Girls could have a hidden agenda.
They want to come and see if your secretly meeting any bishes.
he does know..
lol my missus has already said "If I dont come you'll probably just meet up with you SAU girls"
What SAU Girls.?
lol seriously
loooooool sau girls
She's also a member on here, before she knew me...
She drives a 2 door turbo'd Pulsar VZ-R that would rape Mohomo's car, and previously owned a 32 GTS-4 which she put an RB25 in and converted to manual :wub:
Its amazing how things are so much cheaper in US.
Hiring a base model Falcon or Commodore here is no less than $70 here for a day but you can hire a premium/luxury barge like a BMW series 3 for the same price
Edited by Flynnn
What a mad bish :)
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
