Nah remember when me and alvin just booted it away from the group? Then you had to catch up to us?
We didn't know how fast we were going when we got away from your group, so I pulled out gps and we maxed out 4th. :D
Edited by PENGUYEN
winton, the place where you break stuff..
misfiring 1jz (sparkies i reckon)
drivers side door wont open from outside, (needs some cable ties i think)
passenger window regulator finally gave up the ghost for real.
i'm slightly depressed.
Pretty f**kin shit roads on the drive home...
Was good to drive a car with a bit of go for a change though
Was looking for youto put a face to your name. Couldn't find u. Mohsen was looking for you to supposedly beat the shit out of u.
U leave early?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
