I wish I hadn't slept in and got to meet a few more people, Alr33x THAT WAS YOU WIT Billy yeah when I swapped grille & foggy with him? Also saw Moh on his way out when I was on my way to look at the SnS.
yeh man that was me :thumbsup:
Birds took a punt and assumed I was me at the track...
I thought who's this sexy couple (nohomo) and the tatts were a dead giveaway. We were gonna come out to the party but Alvin's scotch fillet took forever to prepare (shit was worth it) so stayed in and drank at home.
Mother f**ker was cooking steaks and I wasn't informed/invited?
The kebab and The land of goat sphincter rings bread pizza I had for dinner at Mustafa's kebabs (inspire by funky's check in and photo from Friday night) was quite good, but still...
haha, if i could still stomach steaks i would have stayed back guys
i some how ended up with stefan and the other guys lol, and rofl at alvins face when he walked in and saw what was on the computer
