Why not just ignore him. Lol. Waste of time.
That's what I'm doing now.
posted a pic of my car, he put in his 2c and I left it at that, I have no desire to screw that thread up with an argument
have you finished the golf yet shan?
haven't started yet. waiting for engine to blow to do everything including 3.2L swap. the 2.slow just keeps going.
I don't have time to run around and do all this shit, so gonna get craig to organise the 200sx mods etc, I just finance. In exchange he'll co-drive.
shan is the crappymoto 33 bolt in cage?
yes, cusco
Build is ON.
Just bought a GT-SS turbo, and Rush is sorting out a manual conversion kit for me.
Gonna do some light mods to the 200SX to start racing it in standard class :D
GTSS for the 200sx?
what 200sx?
what happened to the 240?
sell cage?
200sx that's been sittin in my garage for 3 years.
240 got sold to some guy from Sorrento.
Cage not for sale.
GTSS for the 200sx?
Yeah. It's regarded as an equivalent of a standard nissan turbo, which is legal?
Driven an SR20 with it before, and the response is amashing.
wrong car, the white 32 with plexi windows is the one.
Really? Nah because I specifically heard from the owner. He said the engine is an old one from Ben from racepace and in street it ran 1:16s? So be said because its stripped it would run faster.
Shan - Stop lying, you ain't entering peanuts... I saw your head at Nats but then didn't see you again ps krapimoto 33 is terrible
lick my balls kent. i'mma do what I want.
we know the kaki's lookin run down, we pulled it out of the back yard after a year of sitting there, washed it, then drove it to Nats. u mad cos we stylin on your ghetto ass with 325's without even tryin?
faaaaaaaaarrrrrk ok I think I need some surveillance type cameras that I can setup from inside the windows to film the front door and outside my bedroom windows/gate. Any of u guys have any advice about that kind of stuff?? Like what to get, where to get it?? Please PM/fb msg/something?
Enter the kakimoto 33 in next Sau track day? Haha
Why? Lol paranormal?
Sounds serious. Some guy with weird hair coming after you?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
